Discussing Engine Popping in the 5.0 Mustangs Forum. I am from Ohio but I moved out to Cali for the Marines. So I ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Engine Popping |
set the timing back to 10 degrees
92 notch project ..new plans.. 2.3l turbo anyone with 2.3 block or complete motor lyin around pm pleaseeeeee(someone in the new england area)
+1, do that and see if the popping goes away.
393 dropping in a foxbody near you, very very soonMilitary Crew E-3 Combat Engineer |
1990 Mustang LX
9.36@143 mph
When did it start popping? After you put the new ignition components in? Finding out when the problem started will help greatly in determining the problem and what to do to fix it. Otherwise you might be chasing your tail for a while.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
heres my 2 cents.......... make damn sure that the 6al box has a real good ground..................
all 4 one & one 4 all |
well the 6AL is under the driver seat and i ran the same gage wire all the way to the battery for the positive and negative. The car did pop before the box but the car ran like shit before because the A9L computer took a dump on me and during that I put in the pro bullit dis. but it ran like shit because of the EEC so i dont really know when it started but I am going to replace the plug wires if that doesnt work then i am going to set the timing back if that doesnt work i am going to hook up some C-4 to it
oh yeah !!!!!!!! i have got the same setup you have also got to use the msd blaster2 coil you must have 50'0000 volts on it......i used all msd on mine so far no problems!!!!!!!!! knock on wood!
Threads Similar to: Engine Popping
| Exhaust popping | energiesource | 99-04 | 13 | October 17th, 2007 07:42 PM |
| Popping noise? | BrightWhite98GT | 96-98 | 4 | July 22nd, 2007 11:46 PM |
| Engine Popping | shawn91stang | 5.0 Mustangs | 4 | January 7th, 2007 02:50 PM |
| Popping out of 2nd | weems | Drivetrain | 7 | October 15th, 2006 10:57 PM |
| downshift 'popping'? | ttop5.0 | 5.0 Mustangs | 7 | August 27th, 2006 10:04 AM |
