AFM cold air MAF and stuff
Ok im plannin 75 mm throttle body and anderson ford power pipe....wat is a good 80 mm MAF that will go on the pipe that goes down in the fender and will i need some kind of extension for the maf wires
how about pro-m 80......?????
ok i know im just tlkin to myself but im haveing trouble finding the pro m 80 on a site that sells them.....calibrated for 30 pounders btw
1991 mustang 5.0
75mm throttle body on a stock 5.0?
1989 GT
KB 2.1L Flowzilla
Thats the combination that im looking for too. Yea you probably will need to extend the wires. Efi components sell Pro-M on eBay, and LMPerformance too.
Pro-M,pro-m mass air, pro-m racing, pro-m mass air meters, Mass Air Meters,MAF, 80PP Jegs sell them also, but for some reason doesnt list the 80mm on their site. 75mm tb sounds too big for stock 5.0, as do 30lbs. Are you planning on maybe power adder or stroker? |
how about abaco?
im plannin at least 347 put hopefully 408 down the road this is all part of a bigger build....if i did do trickflow intake 30 pounder with this other stuff mentioned wud that actually slow it down for now since its stock heads right now and stuff
your heads and headers i think would kill you
yeah i definitely know its not gonna make it full potential at all untill i get heads and full exhaust but those thing are all in the plans too......but would it help or hurt me to have all that stuff on with the stock heads and probly some sort of mild cam....its probly a letter cam....the guy i bought it from didnt know he just said it had a cam in it.......surely it wouldnt actually hurt performance would it.....i have heard you can still run 30 pounders on the stock computer tune
dont put that big maf on until your engine is built and it actually needs it. you wil lose power if you put anything bigger on a stock motor
I wouldn't worry about the throttle body. SCT and PMAS are good mass air meters. Extending the harness is simple if you have some wire, solder gun and solder.
A bigger mass air doesn't hurt horsepower but too big of a throttle body can.
SCT and PMAS (pro m) are the only two maf companies i'd go with.. never had a problem from them and i'd go with a smaller TB one that matches which ever intake combo you go but no larger then a 70mm.
Trickflow intake and larger maf won't hurt performance but sticking 30lb injectors on will make you run rich as a hell without a proper tune.. |
1992 Lx
11.39@119.24
why not save for something you could use now as well on the stroker motor, like heads
The Razor's Edge
switch to speed density
1993 Mustang
we'll find out when i come home from iraq.
very well put
shut up before i punch you in the throat |
I dont know what u will be getting but i have an AFM Powerpipe on my N\A motor. When i bought it a few years ago and i still think it holds tru still but not sure that u have 2 use a shorty style meter. I bought the power pipe & pro-m shorty 80mm meter at the same time from AFM. I know there is little or no room in my fender 4 a longer meter. Might want 2 look in2 that..
well my injectors are crap so i was wanting to go ahead and get new ones and i wasnt wanting to have to upgrade twice was y i was goin with 30....i ges ill do 24s for now.....thats the reason i was doing all of those things....i was gonna go with the 4 inch afm intake also.....so can i use the stock maf with the 4 inch anderson intake if i went ahead and got that
no u cant because the mass air mounts on the end with the power pipe. at least mine does. it comes with the pipe and a rubber elbow 2 go 2 the TB. Also if u dont know already dont forget your stock mass is calibrated 4 19lb inj. and wont work right with the 24's..
man this sucks......i cant do any of these upgrades one at a time.....this blows.....i guess ill just put on the trickflow and thats it
Threads Similar to: AFM cold air MAF and stuff
| JLT cold air intake maf sensor question | SilverStang03 | 99-04 | 4 | May 2nd, 2008 05:19 PM |
| Ram Air Shaker System vs. Cold Air Intake | scxc15 | V6 Mustangs | 9 | January 28th, 2007 01:22 PM |
| jlt cold air or march ram air kit with k&n | jagstang96 | 96-98 | 19 | January 11th, 2007 06:37 PM |
