Discussing No Spark need help in the 5.0 Mustangs Forum. hey yall i thought i was having a timming problem but its a spark issue ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
No Spark need helpi have pos going from batt thru resistor to switch to coil and neg from batt to coil and dist wire to neg on coil. |
Look Ma! My First Post!
86 F-150 302 daily driver 86 gt - tops 351, jugged and c4'd 1.57 60ft 6.57 1/8th 107mph waiting to up the pills http://www.moddedmustangs.com/forums...kesyou_750.gif |
If you are using an older points distributor, the negative of your coil goes to the points only, the coil makes it's ground through the points opening and closing, this is how the coil is triggered to spark. It looks like you have 12 volts going right through the coil to ground, bypassing your distributor/points. Hope this helps |
Threads Similar to: No Spark need help
| NEED HELP Please. NO SPARK AGAIN | noyz25 | 5.0 Mustangs | 9 | August 15th, 2007 07:08 PM |
| not getting spark right away | beheivjer | Modular Mustangs | 8 | May 30th, 2007 03:33 PM |
| No Spark???? | brent_cosenza | 99-04 | 11 | April 16th, 2007 09:41 AM |
| car won't get a spark... | Philly | Engine | 14 | March 24th, 2007 05:46 PM |
| no spark | blackstang333 | 5.0 Mustangs | 10 | March 22nd, 2007 07:07 PM |
