pinion gear install - Page 2
Old January 4th, 2009, 11:27 AM   #21
baine21225's Avatar
Originally Posted by Darrell View Post
It depends if you over gear the car or not. Alot of people over gear because they think bigger is better. Too much gear can reduce your trap mph but could also result in a lower ET because of faster acceleration in the first half of the track.
i'm putting 4.10's in an aod, figured that was a good fit
Old January 4th, 2009, 11:29 AM   #22
baine21225's Avatar
Originally Posted by Iwannagofast View Post
i really think you should do a write up with pics on the whole procedure because im about to do the exact same thing to my car.....also how do gears affect your trap speed at the track....i have heard people say that they went faster and some said that have gone slower
i don't have enough knowledge on the subject to post a write up, my uncle is going to do most of mine
Old January 5th, 2009, 12:16 AM   #23
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
yeah im actually gonna dive it my installation tomorrow.....i havent ever done it but read a lot about it on this site.....i have a buddy coming over that did a full gear install into a dakota he used to have so i think we will be able to get it finished eventually....ill probly be on here askin some questions tho through out the day.....and about the mph vs et question....im goin with 3.73s....will i lose mph or gain....me and my roommate have been wondering....i know the et will be fast....this will be 1/8th mile and 1000 ft track
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old January 5th, 2009, 12:54 AM   #24
1992 Lx
11.39@119.24
it was easy we did mine today, but it whines therefore i will give no advice cuz it wont be very good
Old January 5th, 2009, 02:12 AM   #25
1990 Mustang GT
i know you guys have more experience but how long did it take you start to finish....and where can i get the bearings pressed on at
1990 GT
2004 Impala SS
2001 Tacoma
Old January 5th, 2009, 11:25 AM   #26
1992 Lx
11.39@119.24
call a machine shop, and it took us maybe 4.5 hours to pull my diff off, my friends diff off, tear them both apart and another spare one that the 4.10s came out of, put everything back together and put both diffs back on and bleed the brakes, if it was just one car it prob woulda been more like 2.5 hours, and just grab a phone book and look for machine shops by you
Old January 7th, 2009, 12:43 AM   #27
Brian@PAR's Avatar
Brian@PAR is on a distinguished road
If your installer does not have all the tools and equipment to do the job then you are best off going to someone else. Pinion depth should be measured although it can be done with only marking compound. Backlash has to be measured.
The pinion depth is set by placing shims under the pinion bearing, which is pressed on. If you have to set the depth without measuring you have to guess at the shim thickness, set it all up and check with marking compound. If it's wrong then you have to take it all back apart, pull the bearing off, guess on the next size shim and do it all over again. To get it set up right can take a long time.
Take a look at this write up.
8.8 Axle Gear Install
It's not a hard job for someone who is experianced and has all the right equipment. If you are doing it in your driveway it can be a real bear.
PeteAndersonRacing
Old January 7th, 2009, 12:46 AM   #28
baine21225's Avatar
good write up, my uncle is a car junky with a lift, i'm just going to hover mostly...thanks for the helpful info
Threads Similar to: pinion gear install
bad pinion gear Toph6888 V6 Mustangs 2 June 5th, 2008 05:26 PM
Ring and pinion gear question 06silvergt 2005 - 2010 2 September 13th, 2007 05:29 PM
3.73 gear install? izze01 5.0 Mustangs 12 June 26th, 2007 10:03 PM
Gear install 04gt 99-04 7 June 17th, 2007 06:09 PM
just got my 4.10 gear and pinion spero 99-04 8 April 20th, 2007 03:23 PM
