pinion gear install
Old January 3rd, 2009, 11:16 PM   #1
baine21225's Avatar
pinion gear install
do i need to remove the rear axel?
Old January 3rd, 2009, 11:39 PM   #2
91cobra5.0's Avatar
94 GT
Yes. You have to take both out and the whole ring and carrier out
94 GT - Deep Forest Green
Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block
Old January 3rd, 2009, 11:52 PM   #3
baine21225's Avatar
third member included?
Old January 4th, 2009, 12:03 AM   #4
qwkvert's Avatar
1989 lx convertible
10.87 @ 128 ( old 302 combo)
qwkvert is on a distinguished road
everything must come out. Why are you pulling just ur pinion anyway? just curious. If you are replacing ur gears, you need to ask someone who has done it before to help you setting them up bro, it is not a novice job for sure, or even an intermediate imo.
A bigger motor with a lot of parts they said would make me go faster......
Old January 4th, 2009, 12:30 AM   #5
baine21225's Avatar
i'm definitely not doing it myself, my uncle used to be a mechanic and knows how to do it, i was just curious if it all had to come down. yes i am replacing gears, going 4.10; also rebuilding the trac-lok white its out and adding a new trickflow girdle
Old January 4th, 2009, 01:09 AM   #6
91cobra5.0's Avatar
94 GT
Make sure that when u start taking it apart I can't remember the name but the big u "clamps" holding the ring and carrier in have 1 arrow on each make sure u mark which is left and right, and the arrows have to be pointing out away twords the tires
Old January 4th, 2009, 01:16 AM   #7
baine21225's Avatar
duly noted
Old January 4th, 2009, 01:29 AM   #8
MMs Ford Racing Nut Swinger
1FUN4RD's Avatar
2007 MUSTANG GT
1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold
C-clips?
www.1fun4rd.blogspot.com
Old January 4th, 2009, 01:31 AM   #9
baine21225's Avatar
what about them?
Old January 4th, 2009, 01:40 AM   #10
1FUN4RD's Avatar
2007 MUSTANG GT
Read 4 posts back
Old January 4th, 2009, 01:52 AM   #11
baine21225's Avatar
should i replace the c clips?
Old January 4th, 2009, 02:02 AM   #12
1FUN4RD's Avatar
2007 MUSTANG GT
No
Old January 4th, 2009, 02:10 AM   #13
baine21225's Avatar
then can you explain to me what you mean?
Old January 4th, 2009, 02:12 AM   #14
1FUN4RD's Avatar
2007 MUSTANG GT
He said U clamps & I was asking if he meant C-clips. But after re-reading it I am guessing he meant the bearing caps.
Old January 4th, 2009, 02:47 AM   #15
91cobra5.0's Avatar
94 GT
There u go the bearing caps, that name works better lol
Old January 4th, 2009, 02:49 AM   #16
baine21225's Avatar
ok, got it
Old January 4th, 2009, 11:17 AM   #17
qwkvert's Avatar
1989 lx convertible
post up and let us know how u like them new 4.10's, and if you have any tread left!LOL.....
Old January 4th, 2009, 11:59 AM   #18
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
As in remove the axle assembly from the car? No.
Old January 4th, 2009, 12:06 PM   #19
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
i really think you should do a write up with pics on the whole procedure because im about to do the exact same thing to my car.....also how do gears affect your trap speed at the track....i have heard people say that they went faster and some said that have gone slower
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old January 4th, 2009, 12:22 PM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
It depends if you over gear the car or not. Alot of people over gear because they think bigger is better. Too much gear can reduce your trap mph but could also result in a lower ET because of faster acceleration in the first half of the track.
Threads Similar to: pinion gear install
bad pinion gear Toph6888 V6 Mustangs 2 June 5th, 2008 06:26 PM
Ring and pinion gear question 06silvergt 2005 - 2010 2 September 13th, 2007 06:29 PM
3.73 gear install? izze01 5.0 Mustangs 12 June 26th, 2007 11:03 PM
Gear install 04gt 99-04 7 June 17th, 2007 07:09 PM
just got my 4.10 gear and pinion spero 99-04 8 April 20th, 2007 04:23 PM
