ground
maybe a really dumb ? but where should i hook up the ground...
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump and more to come
1993 Mustang
we'll find out when i come home from iraq.
to the gastank!
shut up before i punch you in the throat |
The Hammer
Millenium Falcon
to any bolt bolted to the chasis
ground for what?
i'm guessing you mean for a battery? if so use a nice size nut and bolt and bolt it to the frame, make sure it is a clean(no rust, even use sandpaper) surface to get a quality ground, then you should be set to go
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
To the battery.
1993 Mustang
lol hook it to the gastank, put peanut butter in the cylinder walls for better lub and cut out your floor boards so you can push the gas pedal down farther to go faster
thats what i was looking for thanks
no problem, might want to sped the extra and buy stainless too. looks nicer and stays looking good
Threads Similar to: ground
| Ground straps | flattusmaximus78 | 5.0 Mustangs | 2 | October 11th, 2008 01:53 AM |
| Ground Effects | supermachone | The Clubhouse | 2 | February 18th, 2008 06:06 PM |
| Ground Problem Need Help! | the88-5.0 | 5.0 Mustangs | 12 | December 12th, 2007 01:15 AM |
| Ground cable | stano76 | 96-98 | 2 | November 12th, 2007 08:32 AM |
| bad ground? | bobvogel44 | V6 Mustangs | 4 | April 5th, 2006 02:24 PM |
