![]() iTrader: 1 reviews
Help CYLINDER HEAD, TWISTED WEDGE
I am getting a set of heads.
I got the U/L intake and stage one cam. I am looking at the heads and I see NON O-RINGED WITH UPGRADE SPRING and O-RINGED WITH UPGRADE SPRING I got a 94 GT, I am using EGR, so does it matter which one I got ? What is the difference? Thanks |
Just get the non o-ring heads. You don't need o-ring gaskets. I would suggest the upgraded valve springs though.
Well I got almost EVERYTHING from the TFS Street Heat Kit.
Only thing I need now the the heads. I got the rocker, pushrods etc.. So the non o-ring valve spings. Here comes the stupid questions. Doesn't springs come with the heads? I'm looking at http://www.adperformance.com/index.p...roducts_id=430 And this.. http://www.latemodelrestoration.com/...0%201&comp=LRS << I know this one comes with the Stree heat kit right?
Giving Away For FREE PM ME. FREE 351 Block, 90,xxx miles (Non roller block) FREE 94-98 GT Hood (red) |
i bet summit has what you want as well.
Valve springs come with the heads but they offer a .600 lift upgraded valve spring set which is what I recommend.
OK, am I am also getting an options of chamber size, 56 and 61cc which one, should I go with?
#7 | |
Naturally asprirated - 56cc supercharger or turbocharger - 61cc
Kool thanks for the help.
depends on you.56 cc will give you like 0.2 more compression or something over the 61 cc heads.if i remeber correctly thats the only big dicideing factor
Darrel is the man on here when it comes to this stuff, do what he says.
#11 | |
Threads Similar to: Help CYLINDER HEAD, TWISTED WEDGE
| B cam with twisted wedge heads | dr.gonzo! | 5.0 Mustangs | 13 | March 3rd, 2007 07:31 PM |
| twisted wedge | dr.gonzo! | 5.0 Mustangs | 3 | January 26th, 2007 02:46 PM |
