Intake systems
Old December 29th, 2006, 08:08 PM   #1
shurb125's Avatar
1993 Mustang LX Vert
shurb125 is on a distinguished road
Intake systems
I want to replace the factory intake system, what do you recomend as far as type, name brand, etc to get the best quality for the money. And when replace do I have to change the throttle body,EGR spacer and the MAF. I have purchased a set of 24# injectors that I will install at the same time. It does have a BBK CAI system and underdrive pullies. Thanks in advance for your suggestions.
Old December 29th, 2006, 08:58 PM   #2
Moderator
89StangGT's Avatar
SVT Cobra Mustang
89StangGT has a spectacular aura about89StangGT has a spectacular aura about
Send a message via AIM to 89StangGT
in all honesty the 24lb injectors will probably be a bit much for a mostly stock motor. a buddy of mine has a set in his mostly stock motor other than intake/exhaust and CAI and it runs really rich.
There's a reason Ford codenamed them the Terminator
Old December 29th, 2006, 09:06 PM   #3
shurb125's Avatar
Well i havent purchased the injectors yet just bidding on ebay, but as for as intake upgrade what would you reccomend or would you spend the money in other areas.
Old December 29th, 2006, 09:48 PM   #4
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
I am assuming you are talking about the intake manifold since you are saying you will be installing injectors with it. Honestly, it all depends on your setup and what you are going to do with it. You want to get an intake that flows with your heads. You don't want to get a holley systemax intake or something else on that level while you are still running your stock heads. If you don't want to get a set of heads anytime soon at all, just get a cobra intake or something. You can find them used for cheap enough.
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old December 30th, 2006, 03:58 AM   #5
how much money do you have? Buy the trick flow top end kit for $2500 or less.
www.summit.com
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old December 30th, 2006, 10:14 AM   #6
stang94 is on a distinguished road
www.summit.com
Save up and get that man, if you really want a kick from that poney,
do some gears and save up for the kit... you'll like it.
Threads Similar to: Intake systems
oil cooling systems wadepetersen V6 Mustangs 2 August 27th, 2007 12:45 PM
Exhaust Systems Snipe061 V6 Mustangs 3 March 6th, 2007 11:08 AM
Exhaust Systems! FastBack71 Modular Mustangs 5 February 26th, 2007 04:42 AM
exhaust systems villatic V6 Mustangs 20 January 29th, 2007 10:38 PM
Exhaust Systems... bcp5008 V6 Mustangs 15 September 5th, 2006 12:16 AM
