351 heads on 302
Old December 30th, 2006, 01:38 AM   #1
Booger is on a distinguished road
351 heads on 302
well i just picked up a 88 stang for $200 its got the american racing rims, true duals(no h-pipe) headerman headers, offenhauser 360 intake, and a holley carb, electric fan,C4 tranny, valve covers, hurst shifter, and some other goodies. i think thats a ok deal. but motor smoked from pass side and had a lil knock from driver side, pulled off valve cover and head says 351 and the whole valve train is Crane. turns out the No.5 Cyl has a push rod that look like a C and was so bent it was shaving itself on the head-explains noise-. what would cause the push rod to bend that bad? the rest were good just one really bad one. it had flat tappet hydro lifters and a small cam like a b303 but made by carne and the cam had broken edges on the lobes.
my question is what does a 351 head do to a 302 performance wise?
also the heads had homemade port job. how do i tell if the valves are any bigger.
Old December 30th, 2006, 02:38 PM   #2
5-0stank is on a distinguished road
i dont think the heads would cause a pushrod to bend...valve springs might???
1995 GT::Sold!
Looking for another stang...
Old December 31st, 2006, 03:50 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
351W heads and 302 heads are almost identical except for the head bolt holes. 351W heads use a 1/2 head bolt hole and 302 heads use a 7/16 hole. 1969 and 1970 351W castings used slightly bigger valves and possibly slightly bigger ports than the 289-302 heads.
Old December 31st, 2006, 06:41 PM   #4
Velvet Leopard is on a distinguished road
Too stiff a valve spring or a bad adjustment will definetly cause a push rod to bend and cause the lifter to dig the cam. Roller lifters would have at least saved the cam's life. This sounds almost like a Chevy Porcupine Modification. I am not sure if the 351's heads have different dimensions water and oil wise, but I know they were NOT designed for the 302 at all. Remember there are three different Base 351 Head designs. Unless the previous owner got specialty parts for this application, I would assume it was an entire hack job. Although it is possible to put big block, and other types, of heads on small blocks, or different types of blocks, which are similar, the cost of the mod would be quite high. I would salvage what parts I could from your engine and either build a fresh 302 or find a good 351 to be sure you have something that fits right.
Old December 31st, 2006, 07:10 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Why is that? All Windsor heads are interchangeable. Everything (steam holes, bolt holes, etc) are the same with the exception of the bigger head bolt holes on the 351W. Most aftermarket heads have the big bolt holes and use a reducer if you put them on a 289-302 based engine. Using 351W heads on a 302 does not consititute a hack job. It is probably a waste of time and effort but is far from a hack job.
Old January 1st, 2007, 03:41 PM   #6
But the deck of a 351Wis higher then a 302, at least mine is about two inches higher. Wouldn't that upset the alignment of the heads, block, and manifold?
Old January 1st, 2007, 05:41 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The deck height of a 351W is 1.3 inches taller than a 302 but that doesn't have anything to do with the heads. 351W uses a different intake than a 302 due to the difference in deck height.
Old January 1st, 2007, 09:02 PM   #8
well i had just bought the car for parts for my other 302. i was just woundering if stock 351 heads did anything for the hp, looking closer at them tonight it looks like a cheap port job and maybe bigger valves?? what size are stock valves and how do i check on the 302 heads?
Old January 2nd, 2007, 04:37 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Most 302 heads (including E7) use 1.78/1.46 valves. Most 351W heads use 1.78/1.46 valves also but 69 and 70 351W heads use 1.84/1.54 valves. Either way you are looking at a minimal horsepower gain which you won't even feel. I'd look for a set of GT40P heads from a 97 1/2 and newer Explorer 5 liter.
Old January 2nd, 2007, 08:44 PM   #10
what kind hp gain would i see from those
Old January 2nd, 2007, 09:43 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
GT40P heads will give you about 25-30hp.
Old January 3rd, 2007, 02:18 AM   #12
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
and GT40P heads come standard on the 5.0 explorers u speak of? or is it some kind of special package or sumthing?
in other words, u can jus find one in a junk yard and take them off of that?
[SIGPIC][/SIGPIC]
Old January 3rd, 2007, 02:22 AM   #13
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
yes they come on the explorers...
My roommate went with 351 heads and he bends pushrods like none other...
Go with the GT40 set-up...IMHO
Facebook
Google+
Old January 3rd, 2007, 04:19 AM   #14
MSO
there has to be a catch.. they're cast iron aren't they?
[SIGPIC][/SIGPIC]
Old January 3rd, 2007, 10:48 AM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes, all 97 1/2 and up 5 liter Explorers
No catch at all. Yes they are cast iron but they are the best factory head Ford makes.
Old December 6th, 2010, 12:02 PM   #16
jrcurtis00 is on a distinguished road
I have a 91 lx coupe. 302 engine. I am in the middle of rebuilding the 302. I have mounted a set of 351 heads with headbolt spacers. The only other difference i've come up with is the size of the ports. Can I resize the ports on my set of gt40 intake or should I look for another intake. I have quite a bit of money tied up in the heads.And i was so wanting to use the gt40upper and lower since I spent about a week polishing the upper.
Old December 6th, 2010, 12:37 PM   #17
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
thanks for bumping an almost 4 year old thread....
damn newbs
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Threads Similar to: 351 heads on 302
GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s BillR1970 Parts 8 May 12th, 2009 09:01 PM
GT40 heads vs GTP heads 99TurboV6Stang 5.0 Mustangs 9 September 18th, 2007 09:34 PM
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 09:55 PM
289 Heads ezra27 General Tech 0 December 30th, 2006 11:09 PM
Boss 302 Heads Same As Cleveland Heads? ken5_0 Classic Mustangs 8 September 25th, 2006 03:18 PM
