Gt40
Hi all....i keep hearing about the Gt40 intake from a explorer will work good on a mustang? can someone explain to me what will the Gt40 will do to the 302. Thanks Mike
they flow better, giving you more horses
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
are those a bolt on or do i have to port them or what
search it, there's tons of great info on the site
The Razor's Edge
they bolt right up. if you port them there going to flow better. the heads off the 5.0 explorers are the same as the 93 cobra. works well with other supporting mods....mainly s/c.....what type of power do you want to make?
you would still need gaskets and such...
The Razor's Edge
no shit sherlock
well believe me, when you say direct bolt on people like my brother would do just that and then say well you guys never said anything about that
The Razor's Edge
i waited for an hour to make sure you knew i was joking...lol
GT40 intakes flow more and produce more torque... they are basically the same as the ford racing GT40 tubular intake and cobra intakes just without the name plate and individual tubes but flow the same numbers.
There are two types of explorer intakes and explorer heads! I forget what years but one version has provisions for sensors and egr where as the other version does not.. which requires you to tap/drill Also there are gt40 heads and then gt40P heads... the gt40 are direct swap and what came on the 93 cobra and first gen lightnings but the P heads are the later style and are a slight gain over the standard 40 head but angled requiring P specific headers and since the plugs are angled it makes plug changes alittle more challenging but if you had the headers or modded a set of headers to fit them there worth it. |
in what year on Explorer do the GT40 and GT40P come out on?
Tks Mike |
85 GT/86 SVO/2010 GT500
gt 40 on 96 gt40p on 97-up
1989 lx convertible
10.87 @ 128 ( old 302 combo)
![]() iTrader: 1 reviews
don't forget the moutaineers... if you do not find an exploder, they are the same...
A bigger motor with a lot of parts they said would make me go faster...... |
I called today and can get a 99 & 97 complete motors for 400 ea
The Razor's Edge
thats not bad at all.....get one throw a sc on it and enjoy block busting power on tap.....
I did that's why they only have two
The Razor's Edge
well i wish i lived closer...lol i would buy one and throw a 150 shot in it
The heads off some Explorers are the same as 93-95 Cobras. 97.5 and newer Explorers and Mountaineers have GT40P heads. All earlier Explorers and Mountaineers have standard GT40 heads.
The Razor's Edge
i keep it in the dummy tearms....because....well....im a dummy...thanks for making me look bad darrell!
Threads Similar to: Gt40
| GT40 heads? | workinprogress | 5.0 Mustangs | 24 | February 2nd, 2009 10:58 AM |
| heads help gt40 | rusty2407 | 5.0 Mustangs | 17 | September 22nd, 2008 01:15 PM |
| GT40 Heads | 95stangvert | 94-95 | 13 | February 4th, 2008 01:26 PM |
| GT40 heads? | workinprogress | 99-04 | 3 | January 13th, 2008 04:02 PM |
| Gt40? | terribleonexx88 | 5.0 Mustangs | 21 | November 10th, 2007 02:44 PM |
