NEED opinions on intake project PLEASE
Old January 9th, 2009, 09:51 PM   #1
flamestang's Avatar
flamestang is on a distinguished road
OK I have a Holley Systemax setup with paxton 2000 that is a driverside mount.With a Anderson Power pipe and PMAS 88mm draw thru maf. I looking to change to a Probe ind. Spyder setup that is a victor jr single plane with elbow and EFI fuel rails.Also get a PMAS blow thru tube and while I'm at it ditch my 42# injectors (that reach 100% DC at 5000 rpm) and get new 60#.
Right now it's set up at 10 psi and starts boost at 3500 rpm.My intensions are to get it to boost faster by having less volume to fill by allso piping over the top of the distributer.
Note this is not a street car track only.
What do you think? sway me please.
Old January 9th, 2009, 10:18 PM   #2
baine21225's Avatar
sounds like an awesome idea, i'll buy your 42s from you when you upgrade...
Old January 9th, 2009, 11:33 PM   #3
flamestang's Avatar
A guy at my work is putting together a 302 and is wanting my intake or to buy a new one.So I found a good used spyder intake.If you want my injectors I'll sell them.They are Summit brand don't know who made them for them.I bought them new for $260.They have about 300 miles on them.Make an offer.
http://http://store.summitracing.com...5&autoview=sku
Old January 9th, 2009, 11:36 PM   #4
1987 ford mustang gt
well see when shes done
I think the summit injectors are made by accel
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old January 9th, 2009, 11:49 PM   #5
baine21225's Avatar
ok, i'll pm you
Old January 10th, 2009, 01:40 AM   #6
Depends what the rest of the combo is??????///
Shorter runner intake with a larger cross section will net you more power and rpm.......
That is if its usable rpm in your case
PeteAndersonRacing.com
Old January 10th, 2009, 09:40 AM   #7
flamestang's Avatar
good point
Old January 10th, 2009, 12:24 PM   #8
Racinjason81 is on a distinguished road
i dont think shortening the piping would help that much with boosting quicker the improvement if any wouldnt be worth the work.if you want to make it boost quicker
you could use a smaller pulley to spin the blower faster(but make sure its within safe limits of your blower)and add a wastegate to the intake piping to regulate the boost down where you want it.For example you could use a 15lb pulley and use then set the wastegate to limit your boost to 10psi so the boost would respond quicker.if you wanted
to go more extreme you could use a Electronic boost controller to adjust it,set boost for different gears,etc.
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old January 10th, 2009, 01:13 PM   #9
flamestang's Avatar
Makes sence.It is a paxton 2000 renegade race system that can make 30 psi.I do have a waist valve and a couple different pullies.I have a 15# pulley (not installed).It is dyno tuned waisting at 10psi now.Wow thanks that was great advice
Old January 10th, 2009, 01:30 PM   #10
how much boost do you wanna run ?How big of a wastegate do you have?see turbo parts can even work on a blower car.
Old January 10th, 2009, 04:21 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The Spyder should make more power because it flows more air. Also keep in mind when you increase the airflow thru the engine the boost level will probably go down. That doesn't mean you are making less power, you will actually be making more power with less boost because the engine is more efficient.
Old January 10th, 2009, 07:17 PM   #12
flamestang's Avatar
I want to keep it around 10-12 psi.It has a vorteck waist gate about 40mm.
Old January 10th, 2009, 07:22 PM   #13
flamestang's Avatar
thanks Darrell that is great advice
Old January 11th, 2009, 03:11 AM   #14
e3sean's Avatar
1988 lx
9.68@142
did u see the pics?
<font size=4><b>MILITARY CREW
Old January 11th, 2009, 02:33 PM   #15
flamestang's Avatar
yes thanks I would like to buy but I need to sell what I have now.
Old January 11th, 2009, 03:20 PM   #16
baine21225's Avatar
hey flamestang nice song choice on the first video
Threads Similar to: NEED opinions on intake project PLEASE
short ram intake or cold air intake????? j/w Stangbro8994 V6 Mustangs 32 September 18th, 2008 08:20 PM
opinions on new project stangfreak The Clubhouse 26 August 31st, 2008 10:52 PM
need opinions for summer project Blk01ponyGT 99-04 11 May 31st, 2008 03:23 PM
95' Mustang 5.0 HO intake swap for 93 cobra intake... stang9587 5.0 Mustangs 1 April 3rd, 2007 05:20 AM
