1990 mustang gt
eventually
clutch
i was thinking about doing this set up
SPEC Stage 1 Clutch (86-Mid 01 GT and 93-98 Cobra) Fidanza Forged Steel Flywheel (86-95 5.0L) thoughts.. suggestions?
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
1990 mustang gt
eventually
bump
85 GT/86 SVO/2010 GT500
I would go with the motorsport stuff it work great and last a long time
spec clutch ftw. whats your setup why not go wtih stage 2 just to be safe?
1990 mustang gt
eventually
i know im not even over 300ft/lb yet
the list is.. 3.55 gears hotchkis upper double adj controler arms 2.5" lowered under drive pulleys trick flow upper and lower intake mac performance 76mm straight shot intake accufab 70mm tb and egr spacer viston 3 core radiator polyurithain(sp?) motor and tranny mounts bbk equal length shorties mac mufflers msd distributor msd master blaster coil msd 8.5mm wires the list i want.. LAK-20150 Control Arms, Tubular, Rear, Lower, Steel, Black Powdercoated, Ford, Mustang, Pair SSB-A112-2 Disc Brakes, 4 to 5-Lug Conversion, Front and Rear, Solid Rotors, 1-Piston Rear Calipers, Ford, 8.8 in., Kit TFS-25200801 Valve Cover Studs, Black Oxide, Zinc Plated, Ford, Small Block, Set of 12 TFS-51400004 Cylinder Heads, Twisted Wedge Street, Aluminum, Assembled, 61cc Chamber, Ford, Small Block, Pair TFS-51400520 Rocker Arms, Stud Mount, Full Roller, Aluminum, 1.6 Ratio, Fits 7/16 in. Stud, Ford,Small Block/351W,Set of 16 TFS-51402000 Camshaft, Track Max, Hydraulic Roller Tappet, Advertised Duration 275/279,Lift .499/.510,Ford,Small Block,Each TFS-51411802 Valve Covers, Tall, Cast Aluminum, Black, Trick Flow Logo, Ford, Small Block, Pair TFS-51520009 Intake Manifold Spacer, R-Series/351W, .375 in. Thick, Gaskets/Hardware, Phenolic, Natural, Ford,5.0/5.8L, Kit
1989 LX coupe 5.0L
might as well get the spec 2 then
#7 | |
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1990 mustang gt
eventually
now what about the flywheel.. do yall think i should go with a Fidanza or a SPEC flywheel?
1990 mustang gt
eventually
whats the drivability of the stage 2? this is my dd
does that mean no your not interested in the cam
1989 LX coupe 5.0L
i have a Fidanza alu flywheel and i have no complaints with it
Skirt Chasing Phallus Phondler
Kit Car/Ducati/Explorer
Nike Fast
Drivability is fine with the stage 2. A touch stiffer but your left thigh isnt going to be bigger than your right after a month of driving...
QUOTE OF THE DAY (5/25/12): “Don’t play what’s there, play what’s not there.” ‐ Miles Davis |
1990 mustang gt
eventually
lol its already stiff as hell.. even though its goin out it still feels as stiff as when i got it
1990 mustang gt
eventually
bump
Threads Similar to: clutch
| Clutch I need a clutch guru | nHuman | General Tech | 2 | September 22nd, 2009 05:12 PM |
| Clutch Or Clutch Cable OR Shifter??? | 96GtGoodz | 96-98 | 21 | July 27th, 2009 02:59 AM |
| clutch replacement- replace whole clutch assembly or just clutch disc? | WilltheThrill | 4V / SVT | 12 | December 13th, 2008 12:18 AM |
| CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS | Hububula | 5.0 Mustangs | 3 | May 28th, 2007 10:08 AM |
| Getting My Clutch Quadrant, Adjustable Clutch Cable and | 97Cobra | 4V / SVT | 3 | May 2nd, 2007 02:33 PM |
