ok so ive been battling a starting issue for awhile now. After the car has run for awhile (up to operating temperature) when i cut it off it will not crank back up until it completly cools down or if i put my battery charger on 275 amp start mode. When i turn the key it turns over barely once or twice then acts like the battery is dead, but when i check it, it is fine at 11.6 volts. Ive redone all the grounds, new battery cables and a starter heat shield. What else could be causing this?
thanks,
Blake
thanks,
Blake
