Electric fan
LinkBack (1) Thread Tools
Old January 12th, 2009, 05:48 PM   1 links from elsewhere to this Post. Click to view. #1
hopper is on a distinguished road
Electric fan
I have been told that a twin electric from a t-bird will bolt right up to my 84 stang. If this is true does anyone have a "how to" wireing and relay help?
thanks
Old January 13th, 2009, 08:44 AM   #2
The Razor's Edge
White Thunder's Avatar
You can get them off taurus's too. There are a few people that have done this. Try searching around or someone might help out
founder of the FTN Club
Old January 13th, 2009, 09:20 AM   #3
don't know about the tbird efans but the dual efan setup out of Dodge Intrepids has worked from me.
it's the same exact efan as this one here
Allstar Performance
It comes in :
1998 to 2004 Chrysler Concordes, 300M's and Dodge Intrepids as well as Chrysler LHS's in 99,2k and 2001. There a two speed setup (hi low) so perferrally you'd want to wire them up to a relay on low or use a controller to use both speeds there's a zillion ways to wire up efans just depends on preference and how safe you want it but be warned that the stock alts in foxes suck balls especially when adding an efan. Also you'll have to trim the shroud a little to get it to fit but it's not a big deal at all.
Here's a pic of one on my daily driver to show how slim they are
http://img.photobucket.com/albums/v2...DSC06773-1.jpg
Aside from that I have a efan out of a taurus on my turbo 91 gt wired to a relay on low speed an has never had a problem.. the taurus fan isn't a dual fan setup but it's two speed and flows someting like 3000cfm which will cool just about aything
Old January 13th, 2009, 11:00 AM   #4
Thanks. The t-bird fits right in, however i am trying to find a way of running the wireing. Should i use the switch like the 2.3 lt use on the heater hose that turns the fan on? or is there an easier way?
Old January 13th, 2009, 11:37 AM   #5
Here's a good write up on how to wire up a taurus efan... it'll give you some ideas
Mustangmotorsport - Mustangs and a whole lot more!
Old January 13th, 2009, 12:43 PM   #6
thanks
Old January 13th, 2009, 02:53 PM   #7
nolife's Avatar
91GT, 88GT, 02GT
Something like the Flexalite 185 fan kit for the Mustang does not draw a lot of power and will work with the stock alternator with no problems. Used pick-n-pull fans like the Taurus fans and similar are cheap but not so cheap if you need to get a 130A alternator, wiring, and thermo kit etc. as well.
Just throwing that out there.
Old January 13th, 2009, 03:19 PM   #8
1992 Lx
11.39@119.24
but you dont NEED to upgrade ur alt with the taurus fan, not on low anyways, which cooled my car in az all summer, but i do have a big ass 3 core radiator and dont like using my ac
Old January 13th, 2009, 04:08 PM   #9
ridebmxfbm's Avatar
1988 Mustang GT Vert
ridebmxfbm is on a distinguished road
Which one flows better the dual e-fan setup or the taurus or how about the lincoln mkIV fan?
1988 GT Vert- 306 AOD built Trans, K&N Cold Air Intake, Mac Catback, many more mods... MAC Long Tubes Coming soon, Dr. Gas Custom X Pipe, 347 Stroker Kit Coming Soon...
Old January 13th, 2009, 04:11 PM   #10
1992 Lx
11.39@119.24
read my above post, i live in az, 112 degree summers, ran my taurus fan on low all summer
Old January 13th, 2009, 04:49 PM   #11
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
I live in albuquerque I used my tauras fan all summer long blasting the ac on low and was fine. There was only like two occasions that the temp came up higher than 180 and I flicked the fan to high and it brought the temp right back down. They work awesome. I rocked stock alt with fan on high and ac and it was a little low on the volt gauge but ran and started fan. Tauras fan ftw
Old January 13th, 2009, 06:05 PM   #12
I agree on my 91 it has the stock rad and fms waterpump and with the taurus efan on low speed wired to a relay/ignition i've never had problems
The dual dodge intrepid setup flows 2800 cfm, the taurus flows 3000 and the lincoln mkiv flows 4000. If you do use the lincoln one make sure you know it pulls serious amps, I've read somewhere in the 60 amp zone and requires a bunch of cutting to fit but that's not hard to do.
Old January 16th, 2009, 12:41 AM   #13
bigjerry916 is on a distinguished road
yo flyin ryan I picked up a dual electric fan off a dodge intrepid and planning to pick up a fluidyne radiator soon. The fan has the harness with about 10inches of wire left on it. whats nxt to make this happen?! i dont want to ran it manually i would like to have kick on automatically.. plz email me at bigjerry916 @ yahoo. com wit some info
Old January 16th, 2009, 12:42 AM   #14
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
i got a set of the fans if you need them.
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old January 16th, 2009, 01:52 AM   #15
You would have to either hook it up to a controller or to a temp sensor with relays but either route you choose has been done before just search on corral.net you'll see.. they use those fans allot over there and the info in link I posted above could help you out as well Mustangmotorsport - Mustangs and a whole lot more!
Old January 16th, 2009, 02:33 AM   #16
87 GT
14.2@98.something
darkhorse50 is on a distinguished road
FORDMUSCLE webmagazine: Junkyard Electric Fan
Old January 16th, 2009, 10:00 AM   #17
Dugger Racing - Mustangs and a whole lot more!
Old January 16th, 2009, 10:21 AM   #18
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
how hp gain do you usually see by doin this?
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old January 16th, 2009, 12:31 PM   #19
The Razor's Edge
something like 20 or so to the flywheel
Old January 16th, 2009, 03:31 PM   #20
notfastenuff is on a distinguished road
Will those work for a 92 fox
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/105314-electric-fan.html
Gmc Syclone ELECTRIC FAN on Kosmix This thread Refback May 10th, 2009 10:42 PM
Threads Similar to: Electric fan
Electric Fan BLUE91GT 5.0 Mustangs 9 January 12th, 2009 01:45 PM
electric fan sixpack 5.0 Mustangs 4 June 10th, 2008 10:54 PM
Electric fan Pony_with_an_attitude 5.0 Mustangs 12 April 8th, 2007 08:45 AM
electric fan vs fan clutch hmotes 5.0 Mustangs 8 December 19th, 2006 03:03 AM
Electric fan or Flex fan? vivoronte 5.0 Mustangs 20 February 10th, 2006 11:58 PM
