Problem with my Notch.
Old January 12th, 2009, 09:03 PM   #1
BoostFiend's Avatar
'03 Cobra, '89 +'91 Notch
11.63@120.08, Cobra
BoostFiend is on a distinguished road
I haven't had time to really look into a problem that I have with my Notch. The other day I was driving home and I noticed a slight squealing sound along with a soft rattle/clank coming from under the hood. When I got home I popped the hood, listened a bit and shut her off. My conclusion was that a pulley was shot. I let her sit for a few days and yesterday decided to check into it a bit more. I went to start the car up and there was a horrible grinding/squealing sound coming from the motor, definately not a pulley. It was so bad I didn't even chance starting the car up.
1 friend thinks its the water pump and another guy suggested taking the belt off to see if the sound is still there to narrow down the pulley diagnosis. Any thoughts or ideas?
Old January 12th, 2009, 09:06 PM   #2
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
the belt idea is great place to start
Old January 12th, 2009, 10:38 PM   #3
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
Yeah remove the belt and turn all your pulleys by hand. You should be able to feel the bad one.
Old January 13th, 2009, 12:56 AM   #4
I agree and im going to call as being the belt tensioner pulley
Old January 15th, 2009, 07:58 PM   #5
BoostFiend's Avatar
11.63@120.08, Cobra
It was the Alternator. I am just gonna get a 130 amp alt and call itgood anyhow. I am going to replace the smogpump pully as well considering it seems to be going as well.
Old January 16th, 2009, 02:15 AM   #6
Nice 5.0's Avatar
1993
12.9 @ 105
If your getting resistance or play on the the smog pump it's not the pulley it's the pump. The pump has bearings in it and the pulley attaches to the flange on the pump. You will have some resistance on the smog pump but it should be light similar to the water pump or power steering pump.
Old January 16th, 2009, 02:24 PM   #7
BoostFiend's Avatar
11.63@120.08, Cobra
Hey thanks, yeah it has alot more resistance than the p/s or water pump. Must be part of the problem. Time to do a smog delete I guess.
Old January 16th, 2009, 03:13 PM   #8
ryans88gt's Avatar
Yeah, rip the smog pump off and the tubes going to it. Drop like 30 lbs right there. Make sure you plug the back of the heads though.
Old January 16th, 2009, 03:15 PM   #9
1992 Lx
11.39@119.24
84.5 inch belt, just skip the smog pump until you delete it
Old January 16th, 2009, 03:28 PM   #10
notfastenuff is on a distinguished road
Did that not to long a go with Joe and made a nice difference I think there is a artical on that smog pump delete
Old April 15th, 2009, 11:17 PM   #11
BoostFiend's Avatar
11.63@120.08, Cobra
Can anyone tell me how to reroute the belt, the 84.5 inch seems a bit long even when skipping the smog pump.
Old April 15th, 2009, 11:31 PM   #12
BoostFiend's Avatar
11.63@120.08, Cobra
Disregard fellas, I figured it out.
Old April 15th, 2009, 11:51 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Your friends are smart men.
Old April 16th, 2009, 12:24 AM   #14
Nice 5.0's Avatar
1993
12.9 @ 105
You finally fixed it. This started in January.
Old April 16th, 2009, 01:29 AM   #15
BoostFiend's Avatar
11.63@120.08, Cobra
Yeah I have had alot of stuff come up so I have been storing the car at a buddies place. In the process of installing the 3.55's, MSD Box, doing a rear brake job, and putting the battery back under the hood instead of in the back seat where the previous owner had it, etc. Hopefully be able to take her to the local track in a couple weeks.
Old April 16th, 2009, 09:15 AM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
So what was the problem?
Old April 16th, 2009, 10:27 PM   #17
BoostFiend's Avatar
11.63@120.08, Cobra
We were routing the belt wrong to bypass the smog pump.
The solution to the original problem was a bad alternator. Got a nice new 130amp.
Threads Similar to: Problem with my Notch.
Notch to get 88 v8 3521 5.0 Mustangs 14 December 21st, 2008 03:45 PM
Best looking notch White Thunder 5.0 Mustangs 42 December 18th, 2008 06:02 PM
92 notch terribleonexx88 2.3 Mustangs 5 July 21st, 2008 11:54 PM
92 notch terribleonexx88 5.0 Mustangs 19 June 15th, 2008 08:06 PM
