Removing Distribuitor
How hard is it to remove the Distributior? I need to install a new Pick up coil in the Distribuitor.
85 GT/86 SVO/2010 GT500
you don't have to pull the distributior to replace the pick up coil
one bolt but you better take note of how it's sitting or else you'll be redoing your timing after you slide the dizzy back in
The Razor's Edge
+1 i just did this on my 305.....damn back of the motor dist!
1988 lx t-top
removing it is the easy part, getting it back in sucks
Don't I have to move the rotor to the #1 spark plug?
#7 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
If it ran fine before dont move anything. leave it in the position it is in. Make a line with a marker on the plastic housing where the rotor tip is facing. then try to mark it where the dist shaft meets the block. (there should already be a small notch.) If there isn't make a line on the block and the dist shaft. unbolt the hold down bolt and pull it out. getting it back in is kinda tricky but dont force it in.
Threads Similar to: Removing Distribuitor
| removing the cat | Dettling23 | 2005 - 2010 | 4 | July 30th, 2008 04:28 PM |
| Removing AC | moke176 | 2005 - 2010 | 16 | December 19th, 2007 03:04 PM |
| removing foglights | JaxnsGT | 99-04 | 9 | October 26th, 2007 04:38 PM |
| i need help removing these | YNOT | 5.0 Mustangs | 13 | April 2nd, 2007 12:33 AM |
| Removing Old A/C | CR70fastback | Classic Mustangs | 7 | January 18th, 2007 05:19 PM |
