24lbs injectors?
Old January 12th, 2009, 11:52 PM   #1
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
b-on-b 5.0 is on a distinguished road
24lbs injectors?
ok i got a cobra short block with the gt-40 heads bored .30 over along with the explorer intake and it has just the cobra cam and a cold air intake bbk shorties.....the next step i was guna take is 24lbs injectors from 19lbs and a 73mm maf and a 73mm tube from the maf to the trottle body....would it make sense to do this or would it be a waste of money and time?
Old January 13th, 2009, 07:39 AM   #2
The Razor's Edge
White Thunder's Avatar
No need for the 24's unless you plan on future mods. If you do get a new fuel pp while your at it
founder of the FTN Club
Old January 13th, 2009, 08:24 AM   #3
19lb injectors are good until the 280ish mark so I would say you have a little room until there absolutely needed but if your going to be upgrading the MAF and plan on adding some other stuff later might as well
Old January 13th, 2009, 11:02 AM   #4
91 LX
13.7@101
i'd say go for it...then you know your safe. id invest in a better intake and a cam..are you using the cobra computer?
Old January 13th, 2009, 11:14 AM   #5
Do it...more room to grow......
Took my combo with 19s to the max.....
PeteAndersonRacing.com
Old January 13th, 2009, 12:14 PM   #6
The Razor's Edge
if he is not planing on making above the 300 hp mark....he should keep the 19's and spend the money elsewhere
Old January 13th, 2009, 01:35 PM   #7
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
I ran 19's on my car for a while. I made 270 to the wheels and when i got it tuned it was rich through the whole rpm range. I only switched them because I got a deal on a meter and injectors.
Old January 13th, 2009, 01:46 PM   #8
Skirt Chasing Phallus Phondler
1FastFox's Avatar
Kit Car/Ducati/Explorer
Nike Fast
1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future
I have a slightly used set of 24s with a 70mm cobra mass air ( calibrated for the 24s ) and a C&L elbow ( Nitrous Bung isnt tapped ) lying around that I will sell you...
QUOTE OF THE DAY (5/25/12): “Don’t play what’s there, play what’s not there.” ‐ Miles Davis
Old January 13th, 2009, 03:15 PM   #9
The Razor's Edge
sounds like a good deal
Old January 13th, 2009, 08:37 PM   #10
b-on-b 5.0's Avatar
1993 Mustang 5.0 LX
11.45@122.34
hpw much do u want for the whole set up and yes i plan on doing more to the motor and i am guna get a new maf and injectors at the same time and then will move onto an x pipe and better intake like a trickflow street burner
Old January 13th, 2009, 08:38 PM   #11
The Razor's Edge
private message him....
Threads Similar to: 24lbs injectors?
Injectors mustang1072 5.0 Mustangs 20 August 25th, 2008 09:27 PM
42# injectors ? angermgt 5.0 Mustangs 2 April 14th, 2007 12:07 AM
