what is stock voltage on TPS
Old January 13th, 2009, 06:58 PM   #1
tryingtobebest is on a distinguished road
Hi, yes very simple and very easy qestion what is the closed voltage and wot voltage on TP sensor?
Thanks in advnace!
and how many wires does tps have
P.S. registred here to get 75mm thrtotle body and figure out if i can use your guys TPS sensor
Old January 13th, 2009, 07:19 PM   #2
black5.0's Avatar
90 mustang notchback
black5.0 is on a distinguished road
It has three wires and it should .98-.99
306 Turbo Notch D&G Tuned
1999 Chevy Silverado 5.3
Old January 13th, 2009, 11:28 PM   #3
PeteAndersonRacing.com
Old January 14th, 2009, 10:19 AM   #4
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
as close to 1.0 as possible but not 1.0
Cohagan Engineering, Inc.
Old January 14th, 2009, 10:49 AM   #5
08 GT-92 lx
txbkr is an unknown quantity at this point
.95-1.05v
But, I read ideal is to set it as close to .985 as possible. It won't be easy. You'll set it perfectly and when you begin to torque down on the screws the numbers will begin to fluctuate. A bit frustrating. Nevertheless, it's attainable.
Old January 14th, 2009, 01:11 PM   #6
So is it .95 closed and 1.05 v OPEN? you guys gotta be kiding me!
Old January 14th, 2009, 06:59 PM   #7
vfast will become famous soon enough
.90-.98 open is 4.4-4.9 or so only 5.0 comes to it
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old January 14th, 2009, 10:48 PM   #8
Thats what i was hoping for! Thanks alot VFAST!)
Old January 14th, 2009, 10:50 PM   #9
12.8@103... stock motor
11.8@113...150 shot
R0B0T can only hope to improve
adjusting the TPS is a myth...
when you restart the car the voltage will change back to its original voltage...
just bolt it in and check it after you cycle the key once...
•Closed Throttle can be anywhere between 0.6-1.0 volts
•Part Throttle is triggered @ 0.04 volts above Closed Throttle
•Full Throttle is triggered @ 2.71 volts above Closed Throttle
Ford Fuel Injection Throttle Position Sensor (TPS)
Threads Similar to: what is stock voltage on TPS
Stock looking Voltage Meter? Wook660 5.0 Mustangs 0 October 6th, 2008 04:18 PM
Voltage Problem stang300a V6 Mustangs 22 November 9th, 2007 02:44 PM
battery Voltage new 5.0 94-95 3 June 19th, 2007 09:38 AM
What Is Voltage On A Stock Coil ? chadjones99 5.0 Mustangs 5 September 19th, 2006 11:06 PM
Voltage Amp??? My5point0Mustang Audio/Video 5 October 20th, 2005 12:16 PM
