need a new clutch cable.
Old January 14th, 2009, 11:37 AM   #1
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
My clutch cable is adjusted all the way out, and its still hard to get in gearm shift fast, or slow sometimes. So it looks like I stretched the stocker. And not going into gear has made my tranny whine like a mother effer cause when racing it allways grinds. So I'm tossing some fluid in her today and my next investment shall be the cable.
How much do they run and are they hard to install?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old January 14th, 2009, 11:39 AM   #2
1992 Lx
11.39@119.24
adjustable clutch cable, 40 bucks, the same one thats on my car
Summit SUM-700101 - SummitŪ Adjustable Clutch Cables - summitracing.com
Old January 14th, 2009, 12:09 PM   #3
1993 5.ohhhh
12.97 @140mph
Love u lol... Will do. I'm going to destroy my tremec if I continue this route. It leaks a little and whines on the highway now on the street, and grinding gears doesn't help. Is it hard to install?
Old January 14th, 2009, 12:12 PM   #4
Hard as it is to tie your shoe
PeteAndersonRacing.com
Old January 14th, 2009, 12:13 PM   #5
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
make sure u route it right..ive seen many guys destroy cables by routing them wrong
Cohagan Engineering, Inc.
Old January 14th, 2009, 12:15 PM   #6
1993 5.ohhhh
12.97 @140mph
me no smart.... check your pms son... im ready to get those injectors.
Old January 14th, 2009, 12:21 PM   #7
O crap...didnt even see it in there....pm me and refresh my memory about the deal
Old January 14th, 2009, 12:30 PM   #8
1993 5.ohhhh
12.97 @140mph
Fo sho!
Old January 14th, 2009, 04:43 PM   #9
1993 5.ohhhh
12.97 @140mph
How do I add a quart of trans fluid in... or does it all have to come out first
Old January 14th, 2009, 04:54 PM   #10
TKOTLARZ's Avatar
1994 GT
i used a funnel with a tube on the end and there are two "screws" on the side of the tranny..use a 3/8s ratchet to loosen..i put the tube in the top one and wen it starts to come out i stop and tighten..u shouldnt be able to put a quart in unless u been driving around low..a tranny should really hold its fuild..its not like an engine that can burn oil or anything..if u want to jus put some new in for the good of it, jus change it all
Old January 14th, 2009, 04:59 PM   #11
1993 5.ohhhh
12.97 @140mph
its leaking from somewere thats the only reason.
Old January 14th, 2009, 05:10 PM   #12
1993 5.ohhhh
12.97 @140mph
just pulled the top bolt out and nothing came out lol... def need fluid.
Old January 14th, 2009, 05:14 PM   #13
TKOTLARZ's Avatar
1994 GT
its leaking..well its either goin out the front or back...u probably live on an incline to im guessing??wen u take the top screw out it doesnt necessarily mean it needs it..thats right where its should be..but if u try putting some in and i does take it, then ur low..look for grease on front and rear of tranny
Old January 14th, 2009, 06:17 PM   #14
1993 5.ohhhh
12.97 @140mph
The car is parked on an incline, but it drips on flat surfaces as well. When I pulled it into the garage it left a nasty drop. Enough to quench my thirst.
Old January 14th, 2009, 07:17 PM   #15
MOTOIMPAIRED's Avatar
1990 LX Coupe
MOTOIMPAIRED is on a distinguished road
Take care of that grinding fast... My started grinding going into third and now I no longer have a third or fourth gear!!!
Pulling the motor and tranny now and getting ready to rebuild both...
Old January 15th, 2009, 11:35 AM   #16
1993 5.ohhhh
12.97 @140mph
Was that your trans or did you destroy it with the clutch cable. I can't promise its my clutch cable, but its getting harder and harder to go into gear. and then when I try to go shift fact it grinds like the clutch isn't engaging fully.
Old January 15th, 2009, 12:22 PM   #17
uprpat's Avatar
uprpat is on a distinguished road
pm sent on clutch cable.
UPRProducts.com
1995 GT- 277rwhp/305rwtq
Old January 15th, 2009, 02:35 PM   #18
black5.0's Avatar
90 mustang notchback
black5.0 is on a distinguished road
Your going to buy a adjuster and the quadrant right.The plastic on is okay if you have a stock clutch. i just bought the whole kit from latemodel resto
306 Turbo Notch D&G Tuned
1999 Chevy Silverado 5.3
Old January 15th, 2009, 03:52 PM   #19
1993 5.ohhhh
12.97 @140mph
Im trying to make sure its my cable doing this, but the car is getting harder and harder to go into gear. But when I shift without the clutch its ten times easier. Sound about right.
and im on a king cobra clutch is a quadrent worth it.
Old January 15th, 2009, 04:32 PM   #20
black5.0's Avatar
I have a super king cobra clutch and i had to get it so i wouldnt slip.i would get both so you can adjust it. it probably needs to be adjusted so it will release
Threads Similar to: need a new clutch cable.
Clutch Or Clutch Cable OR Shifter??? 96GtGoodz 96-98 21 July 27th, 2009 02:59 AM
clutch cable. flattusmaximus78 5.0 Mustangs 1 August 30th, 2008 02:23 PM
Clutch Cable? Badasstang281 99-04 3 December 4th, 2007 10:16 AM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 10:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 02:33 PM
