Oil Leak.
Old January 14th, 2009, 11:03 PM   #1
Pig Romancer
thewayshemoves's Avatar
2003 GT
300.32@5.02mph
thewayshemoves will become famous soon enough
Send a message via AIM to thewayshemoves
Oil Leak.
Jordan (Jornez) wanted to post this about his fox. When we brought it to his house there was an oil leak, there was oil all over the engine and stuff, but his valve covers were warped so it was leaking like a son of a bitch from there. He got new valve covers and gaskets and it didn't leak for a few days so we thought we had it. Today he noticed that after sitting all night it created a new puddle of oil, and the oil when he checked it on the dipstick was really runny and kind of foamy. We thought it might the head gasket, but there's no other symptoms. No smoke, No oil in coolant, etc. Any ideas?
http://i41.tinypic.com/2qjc2mh.jpg
Thank's your a grate guy and person who is good also
Originally Posted by GTsetGO View Post
it ain't no thang ma fraind. i jus be lukin after yo best intrest
Originally Posted by 93hatch View Post
wow open header crx, that things gota sound like hammered dick
Old January 14th, 2009, 11:10 PM   #2
87gtmustang's Avatar
1987 mustang GT
87gtmustang is on a distinguished road
Send a message via MSN to 87gtmustang
nothing to really do with it but how would oil get in the radiator/ coolant
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump
and more to come
Old January 14th, 2009, 11:14 PM   #3
Pig Romancer
2003 GT
300.32@5.02mph
I don't know what I was even talking about there, I was thinking about why the oil looked so funny and was thinking about coolant in the oil or something I don't know, anyway, no idea what could cause that?
Old January 14th, 2009, 11:24 PM   #4
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
i mean the obvious a head gasket, other than that its possible that the block could be cracked..
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old January 14th, 2009, 11:26 PM   #5
Pig Romancer
2003 GT
300.32@5.02mph
Would a head gasket do nothing but leak oil though? He bought new head gaskets tonight just in case, we're prepared to change them out, we just want to be sure.
Old January 14th, 2009, 11:32 PM   #6
Traidmarx's Avatar
1995 Mustang GT
i was speaking on why the oil was foamy, as far as the puddle of oil under the car...it could be leaking from a number of places..it sounds familiar though to a guy i know that bought a 89 notch back from a guy who claimed the car had been sitting for months because they couldn't figure out the coolant system issues...and he soon found out that they had apparently let the car keep overheating and warped the block..and oil leaking from around valve covers even after they had replaced them 3 or 4 times.
Old January 14th, 2009, 11:33 PM   #7
Pig Romancer
2003 GT
300.32@5.02mph
Damn I hope that's not what's up.
Old January 14th, 2009, 11:35 PM   #8
Traidmarx's Avatar
1995 Mustang GT
i meant warped the heads not block sorry...but that could explain why its leaking oil from the valve cover gaskets, and also leaking coolant into the oil. if the heads are warped they're not gonna seat right on the block and the valve covers aren't gonna seat right on top of the heads. i mean chances are if the valve covers are warped it's possible the heads could be warped too.
Old January 14th, 2009, 11:44 PM   #9
1986 LX
none yet
jtyson8602 is on a distinguished road
sounds like the heads are warped. go ahead and pull them and take them to a machine shop they can tell you. foamy oil could mean that it was overful and the crank was dipping itself into the oil. if theres a bad head gasket you will have milky oil and plenty of smoke. so assume that the valve covers are where the leak is coming from
Old January 14th, 2009, 11:47 PM   #10
1987 ford mustang gt
well see when shes done
have you checked the rear main?
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old January 14th, 2009, 11:48 PM   #11
Pig Romancer
2003 GT
300.32@5.02mph
Not yet, we thought of that too, but it's been too cold to get out there and really look close. That's something we need to check out too.
Old January 14th, 2009, 11:51 PM   #12
Traidmarx's Avatar
1995 Mustang GT
but based on where the puddle is you should be able to tell if its the rear main or the valve covers. unless the valve cover is leaking from the very back...
Old January 14th, 2009, 11:55 PM   #13
1986 LX
none yet
im gonna shoot a guess out there but if they replaced the valve cover gaskets and it fixed the problem for a few days then started again it wouldn'nt be the rear main seal. that will be a constant leak not sporadic. so all it took was the new gaskets on the valve covers to get saturated and leak(assuming head is warped and there isn't a good seal). but you should be able to tell by looking at the valve covers if thats where the oil is coming from
Old January 14th, 2009, 11:56 PM   #14
Pig Romancer
2003 GT
300.32@5.02mph
Well...it's kind of everywhere. We're not sure exactly if it's front of back, because when we first noticed, we just immediately changed valve covers, since there was oil all over them anyway, we just assumed it was them. Then driving it, then coming back a few times, etc. We ended up with a huge puddle, and we don't' have a garage since I've moved so it's been too cold to crawl around under it and really check. I just know changing the valve covers didn't help.
Old January 14th, 2009, 11:56 PM   #15
1986 LX
none yet
and your rear main seal is much lower than the valve covers obviously. so if there is oil on the heads you could rule out that seal
Old January 14th, 2009, 11:57 PM   #16
Traidmarx's Avatar
1995 Mustang GT
yea if you run you're finger all the way around it, you should be able to feel the oil beading up...like i said before i'm pretty sure the heads are warped. especially given the fact that it got hot enough to warp the valve covers.
Old January 14th, 2009, 11:58 PM   #17
Pig Romancer
2003 GT
300.32@5.02mph
That's what I'm thinking now.
Old January 15th, 2009, 12:00 AM   #18
Pig Romancer
2003 GT
300.32@5.02mph
He was thinking about upgrading heads anyway, so we'll look into that for sure. Thanks man.
Old January 15th, 2009, 12:00 AM   #19
Traidmarx's Avatar
1995 Mustang GT
best way i can tell you to check it is, to get a white towel, drive the car around for about an hour or so...then come home park the car...pop the hood wrap the towels around both valve covers go check it a few hours later dirty towels means you probably have warped heads.
Old January 15th, 2009, 12:01 AM   #20
Pig Romancer
2003 GT
300.32@5.02mph
Will do. Probably tomorrow. Thanks man.
Threads Similar to: Oil Leak.
oil leak 87gtmustang 5.0 Mustangs 3 November 2nd, 2008 02:56 PM
oil leak wadepetersen V6 Mustangs 9 May 6th, 2008 02:16 PM
oil leak under Oil filter Genevieve! 99-04 9 February 19th, 2008 08:30 PM
Oil leak? whtpny 99-04 0 November 16th, 2007 12:55 AM
98 GT oil leak from the oil filter adapter??? Nissanguy8 96-98 8 February 9th, 2007 01:08 AM
