Alternator
Old January 15th, 2009, 07:46 PM   #1
1987 ford mustang gt
well see when shes done
Alternator
Ok my car will not charge at all has alt been replace, wiring has been checked over and over. if you ground the regulator out it will start charging. I am pretty lost on this one any help is appreciated.. Also the connector on the harness have been replaced.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old January 15th, 2009, 10:01 PM   #2
ttt..
Old January 15th, 2009, 11:27 PM   #3
The Razor's Edge
White Thunder's Avatar
i always ask you questions....i dunno
founder of the FTN Club
Old January 16th, 2009, 12:38 AM   #4
me either ive checked the wire for corrosion all the way to the solenoid, checked all the connections, checked resistance. Everything i just dont see why the regulator wont kick on without grounding it out.
Old January 17th, 2009, 04:17 PM   #5
ttt
Old January 17th, 2009, 07:56 PM   #6
Speedstang302's Avatar
13.64@101mph
check to mounting for the starter...maybe its torked down to tight or its too loose..that what was wrong with my brother mustang, we replace the wires to it, and i pulled of the starter and we put it back in with a bolt that was only half threaded and wasnt tight enough...
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old January 18th, 2009, 12:46 AM   #7
1986 LX
none yet
jtyson8602 is on a distinguished road
your regulator only says how much. the stator says when. if you still have the stock alt then make sure your white wire on the plug is connecting well with the post. or if youve done the 3g upgrade make sure the same wire is connected well to the separate stator post. these alternators are internally regulated so if it works by grounding it out that may mean that you have a faulty alternator.
Old January 18th, 2009, 02:36 AM   #8
It does not have a bad alt, i know this for a fact both of them have been tested. And the signal wire is connecting fine. Like i said both plugs have been replaced. This car has not run in over 2 years while i have been building it. It was charging fine when i first got the car though.
Old January 18th, 2009, 08:57 PM   #9
1986 LX
none yet
well if it isn't charging there is obviously a problem with either the alternator or the wiring. unless your battery wont hold a charge. where are your alt wires run to? I know a lot of people have them on the solenoid (if yours has the separate starter solenoid) and its pretty common that they put the wire to the wrong side of the solenoid which will give a partial output but not charge. may want to make sure its going to the right side if applicable. But who knows.
Old January 18th, 2009, 10:51 PM   #10
ryans88gt's Avatar
check all the grounds, does the block have a good ground to chassis and battery?
Maybe a blown fusible link in the wiring connecting the activation circuit and the charging wire.
Old January 23rd, 2009, 08:01 PM   #11
ttt
Old January 24th, 2009, 10:13 AM   #12
1989 LX coupe 5.0L
89lx is on a distinguished road
ya i had a fusable link go on me, i was in the same boat three alts later
Old January 25th, 2009, 09:37 AM   #13
fakesaleen's Avatar
1988 lx t-top
fakesaleen is on a distinguished road
i had the same problem, it was the wire to the guage on the dash it tells it to charge just follow the wire
http://i723.photobucket.com/albums/ww234/wendell1988/fakesaleen.jpg
Threads Similar to: Alternator
Which alternator?? Drtbkercr5 The Clubhouse 0 April 10th, 2008 09:09 PM
Alternator JStang14 94-95 2 February 9th, 2008 08:56 PM
alternator Murderjetz V6 Mustangs 6 July 26th, 2007 07:53 AM
New Alternator Thewolfman456 99-04 2 May 8th, 2007 07:31 PM
alternator 89mustanggt 5.0 Mustangs 5 May 19th, 2006 08:43 AM
