am i
Old January 16th, 2009, 11:18 AM   #1
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
am i
supposed to have this much play in my drive line?
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old January 16th, 2009, 12:25 PM   #2
The Razor's Edge
White Thunder's Avatar
have you notied anything wrong as far as driving it. my chevy didnt have quite that much but it had some
founder of the FTN Club
Old January 16th, 2009, 12:27 PM   #3
chickenbot's Avatar
1990 mustang gt
eventually
it bucks really bad at 1500 rpms
1990 gt 5.0
3.55 gears
Old January 16th, 2009, 12:28 PM   #4
hopper is on a distinguished road
there should be some, as long as that play isn't between your yoke and driveshaft indicating a bad u-joint
Old January 16th, 2009, 12:30 PM   #5
The Razor's Edge
yeah check the u joint
Old January 16th, 2009, 12:31 PM   #6
chickenbot's Avatar
1990 mustang gt
eventually
the u joint is tight it seems like its in the tranny
1990 gt 5.0
3.55 gears
Old January 16th, 2009, 12:38 PM   #7
The Razor's Edge
aod or t5?
and this just started happening
Old January 16th, 2009, 12:38 PM   #8
chickenbot's Avatar
1990 mustang gt
eventually
t5
1990 gt 5.0
3.55 gears
Old January 16th, 2009, 12:58 PM   #9
should be a bit of play,
well every t-5 i have had made a little play unless they were all screwed.
