1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
had a bad experience any ideas...
last night here it was 16 degrees with the wind chill it was around 2 degrees. i left work, and noticed that the heat would not get hot...then noticed the motor getting hot...my first reaction was how the hell did this happen...i pull over pop the hood and the block is cold enough for me to touch. So i had text anthony(white thunder) see if he had any ideas. Kinda figured it was the gauge messing up. So i get back in the car drive about 5 more minutes and the temp is getting hotter and hotter, so i ignore figuring it was the gauge. Then notice steam pouring out from the hood so i pulled over again, Coolant had bubbled outta the radiator, so i checked the the overflow, it was full. So the car was hot enough to overheat, full of coolant yet the heat wouldn't get hot. Well coolant kept bubbling over, so it was low at that point so i waited a while to cool off while freezing my ass off eventually made it home. Put more antifreeze and water in the radiator. Started it up and ran fine i drove about an hour to make sure and has been fine since. What i'm thinking happened. is that when i fixed the coolant leak a while back i didn't put the right mix of antifreeze and water and it froze inside the block...what do you guys think??
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. Last edited by Traidmarx; January 16th, 2009 at 12:13 PM. |
probably had the thermostat freeze shut until it overheated in the engine and forced it open.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
i had this same thing happen when using shitty antifreeze or not mixing rich enough.
Also when buying a thermostate don't cheap out. but a good quality one. mine themostate stuck once as well. not fun i feel for you man. drain it, change thermostat and fill with good prestone. |
The Razor's Edge
i think he just bought a new one. i dont know if its a cheapie or not
it is definetly worth the extra buck. I will never by a cheapie again. $8 difference to freeze my ass off, then spend half the day figureing out what is wrong, and thawing out all the line.
NO thank-you |
1995 Mustang GT
yea i hear and it was just some $8 thermostat from advance, i was just more worried that it had cracked the block or something from freezing the coolant, may have just been the thermostat though.
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
Holy shit, the exact same thing happened to me yesterday, I thought my water pump went out, my car just started to over heat so i pulled over and shut the car off and the fluid was coming out of the overflow but the radiator was full so u think I should change my fluid as well and change the thermostat?
The Razor's Edge
might as well its cheap....
85 GT/86 SVO/2010 GT500
just make it is a pop open style that way it always flows (fail safe)
i thought pretty much all of them were made fail safe now? I have to wait till the weather warms up and i get time off work to mess with the car, I think I am going to try and put it in a buddies garage then drain all the coolant and change the thermostat and get new fluid. then see what happens.
No the zone still offers a $8 model
sounds like the thermostat was frozen to me
1988 lx
9.68@142
easy fix move to phoenix and never have a freeze problem ever..
The Razor's Edge
lol sean
13.64@101mph
yeah i've used mr gasket thermostats on almost everything...never once had a problem..and there like 12 bucks
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
90 mustang notchback
Yeah i dont think you crank your block you would know that prett fast.
306 Turbo Notch D&G Tuned
Threads Similar to: had a bad experience any ideas...
| My shitty Sunfire GT | Juggalo_X | The Clubhouse | 6 | October 27th, 2007 03:33 PM |
| shitty day.... | 232stang | The Clubhouse | 11 | September 29th, 2007 04:24 AM |
| What A Shitty Day | itschristorres8 | The Clubhouse | 39 | October 2nd, 2006 03:56 AM |
