Boost gauge install
Old January 17th, 2009, 10:01 AM   #1
blakehunter316's Avatar
1989 Mustang GT
14.01 @ 103..... :(
blakehunter316 is on a distinguished road
Boost gauge install
Ok i am puttin in my autometer sport compIIs today i have a mechanical boost gauge. it says to tap into a vacum line ?? what one would this be? and some one also told me i need to tap a hole in my s/c tubing. which is it? Can any one help me out on this thanks. pics would help to if posible
vortech s-trim off road h pipe super 40's steeda tri-ax c.a.i. 3.73s subframe cnntrs 255er
Old January 17th, 2009, 10:51 AM   #2
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Apologies for going off topic. Are u running your smog pump with your strim. If not did you use a delete?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old January 17th, 2009, 10:59 AM   #3
1989 Mustang GT
14.01 @ 103..... :(
No the bracket assembly just moves it a little bit and the alternator goes beneath it i still have the smog pump.
Old January 17th, 2009, 11:09 AM   #4
1993 5.ohhhh
12.97 @140mph
Is your smog pump still hooked up?
Old January 17th, 2009, 11:19 AM   #5
1989 Mustang GT
14.01 @ 103..... :(
yea it is it takes the tube that drops down lower to reach the smog pump and like makes it straight in front of the rest of the tubing. everything is still hooked up yes. so completely legal other than my non catted hpipe
Old January 17th, 2009, 11:41 AM   #6
nolife's Avatar
91GT, 88GT, 02GT
Any vac line will do, you probably have one on the vac tree on the firewall that is not used.
Not technically related but... When you have boost, you need to make sure ALL of your vac lines have some type of clamp on them or they are real tight. Without boost, the vac lines have a tendency to stay on because they are "sucked" on and never have a positive pressure on them. With boost, the pressure can push them off.
Old January 17th, 2009, 12:08 PM   #7
1989 Mustang GT
14.01 @ 103..... :(
so like on my fire wall the tree will do like any of those lines will give pressure for the boost ? and do i need to re clamp them?
Old January 18th, 2009, 02:11 AM   #8
I used black zip ties on all my vac lines
Old January 18th, 2009, 02:19 AM   #9
1989 Mustang GT
14.01 @ 103..... :(
hmmm well i installed it and it runs at like 14 or 15 vac. i gave it a rev to 3 grand and just managed to get it to just get over 1 psi. so i think it dont make boost till after that any way. so i think it will be ok
Old January 18th, 2009, 02:57 AM   #10
nolife's Avatar
91GT, 88GT, 02GT
Yes, any vac line should okay.
You will not get boost until well into the throttle and under a load and it builds with rpm so your good so far.
I used zip ties too. I still have all of the emissions, charcoal cansiter, fmu, egr, AC, boost retard box etc so there are a lot of vacuum lines. It looks like ass and takes a lot of zip ties but they stay on
Another note. I don't know what instructions or kit you have but somewhere in the install you should have removed and capped off the line from the oil cap breather tube to the throttle body.
Old January 18th, 2009, 10:06 AM   #11
1989 Mustang GT
14.01 @ 103..... :(
hmm can u elaborate on the part about capping something off ? What lines and y ? Thanks
Old January 18th, 2009, 10:50 AM   #12
notfastenuff is on a distinguished road
go off the Vacuum tree on the firewall
Old January 18th, 2009, 03:13 PM   #13
1989 Mustang GT
14.01 @ 103..... :(
I did
Old January 18th, 2009, 03:36 PM   #14
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
if u use zip ties just use the small black ones..u cant even see them..just put the lock part of the ziptie on the back side where u cant see it as much
Cohagan Engineering, Inc.
Old January 18th, 2009, 09:08 PM   #15
1989 Mustang GT
14.01 @ 103..... :(
ok I'll prolly do them all eventually I still got a few months before I can get it out any way
Old January 19th, 2009, 11:54 AM   #16
nolife's Avatar
91GT, 88GT, 02GT
If you leave that line attached, you have a path for air between the valve train/oil side of the engine and the intake. On a car without boost, this is fine, you will always have a vacuum there allowing things to vent. Even at full throttle 0 vac, at least you are not putting pressure there. With boost, you are applying that same boost pressure directly to the engine.
Not the best method but as a minimum, you should remove that line, cap both ends and replace the oil cap with a breather.
Some people go a little further with blocking off the PCV and put a breather on both valve covers. It is up to you and depends on how much blow-by, if oil is coming out of the breather, PCV, or dipstick, or how many gaskets and seals you blow out on what you will have to do.
Old January 19th, 2009, 11:00 PM   #17
1989 Mustang GT
14.01 @ 103..... :(
so just pull that line and cap it on the throttlebody and cap it on the valve cover or put a breather on the valve cover? I'm only runnn 5 psi for now so its not alot of boost but now I'm interested in this. Zip ie all vac lines. And pull that one betweeen the covers and t-b and I'm good ?
Old January 20th, 2009, 09:33 AM   #18
nolife's Avatar
91GT, 88GT, 02GT
both, remove and cap the line AND a single breather and you'll be fine. I run 10-12# with just that and have no problems.
I'd keep that line and oil cap around if you have emissions checks, you may need to put em back on to pass.
Threads Similar to: Boost gauge install
How to install fuel pressure and boost gauge?? Saleenssc14 2.3 Mustangs 19 July 22nd, 2008 11:48 PM
Boost Gauge beheivjer 2.3 Mustangs 10 May 20th, 2008 01:44 PM
89 boost gauge install.need help ASAP hot89 5.0 Mustangs 2 April 3rd, 2008 11:47 AM
boost gauge prinzzz 2005 - 2010 1 December 30th, 2007 06:23 PM
Boost Gauge mmvi V6 Mustangs 9 December 26th, 2007 10:30 AM
