Easiest way to drain tank /Starting issues
LinkBack (1) Thread Tools
Old January 18th, 2009, 03:55 PM   1 links from elsewhere to this Post. Click to view. #1
1987 Mustang GT Bracket
10.983 @ 120.24
Greybeard is on a distinguished road
I have a bone stock project 87 5.0 that I started on about a year ago. Last March I pulled the fuel tank, cleaned and sealed it, installed a new walbro pump, a freshly cleaned set of stock (orange top) injectors, and a new cap/wires and plugs. I also replaced head and intake gaskets, recalibrated the throttle pos switch to .97v and bumped the timing to 12*. On its maiden run it fired at the hit of the starter, and ran like new.
A few days later, was noticeably harder to start - never did fire off at the hit of the key again - always cranked for 3-4 seconds then fired up, stumbled a bit then finally smoothed out as it warmed up. I think the gas was getting long in the tooth back then.
The Stang has been sitting for the past 9 months due to other projects (simultaneouslty building a big ATV, rebuilding the shifter kart and restoring an old land speed race car) getting time to get to it at all has become a real chore.
- I didn't use fuel stabilizer....the gas really stinks and I'm guessing it now has about the same octane rating as cheap beer. I shoulda watched the commercial instead of laughing at Bob in his boat.... I'm 99% sure that this will cure most of what ails it....
Lucky for me it's warmed all the way up to 38* with sleet, and the car last died whilst on the grass, parked under a pine tree. It's not something I'm looking forward to, but I've got to finish this and get the car moved by tomorrow because the rest of my weekends through the end of March are spoken for. It's going to be a real beast trying to jack this thing up because of the low profiles having sunk in the soil (leaving only about 2" of clearance)
1. Can I drain the tank through fuel rail the without having to access the fuel filter? I seem to remember that the fuel pump won't continue to run after the initial key-on time out unless the engine is running.
2. Is there an easy way to clear the existing fuel between the filter and the rail if I can't get a jack safely under the car to get to the filter?
Thanks!!!!
Old January 18th, 2009, 04:01 PM   #2
The Razor's Edge
White Thunder's Avatar
i dont know how to spell it but syphin.....lol they sell them cheap at walmart and places like that...plus you can steal gas.....
i know a guy that tried to get gas out of a tank with a screw driver...lol he started kicking it and shit....too funny
founder of the FTN Club
Old January 18th, 2009, 04:07 PM   #3
1992 Lx
11.39@119.24
yeah just syphon it dude, with that stupid pump thing from walmart if ur scared to use a piece of garden hose and your mouth
Old January 18th, 2009, 04:15 PM   #4
The Razor's Edge
lol...
Old January 18th, 2009, 04:26 PM   #5
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
YEEHAAW I'm gunna get that gas
Old January 18th, 2009, 06:05 PM   #6
The Razor's Edge
my step dad was a trucker.....he was stealing gas at a truck stop....they guy caught him.....he pulled his gun and was like get back in the fucking truck.......fucking red necks
Old January 18th, 2009, 07:55 PM   #7
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
my friends and i used to steal gas from sides of houses and open garages..steal all the five gallons..thats wat they usually were..or off of lawn maintenance trucks...it sucked tho cause i could never use it in my car cause it was always 89..lol
Cohagan Engineering, Inc.
Old January 18th, 2009, 11:00 PM   #8
ryans88gt's Avatar
There is a test connector by the drivers side hood hinge. Ground the correct wire and the fuel pump will pump with the key in the on position.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/106189-easiest-way-drain-tank-starting-issues.html
Free PSP ISO Downloads EUR PSP ISO & CSO Downloads This thread Refback May 2nd, 2012 10:23 AM
Threads Similar to: Easiest way to drain tank /Starting issues
Gas Tank Leaking?? How to Drop your Fuel Tank / Replace the Filler Neck Gasket gills99stang 99-04 66 May 19th, 2012 02:49 AM
Maf Conversion Starting Issues mad squables 5.0 Mustangs 1 March 3rd, 2008 03:44 PM
98 starting issues still beheivjer Modular Mustangs 5 July 13th, 2007 02:48 PM
starting issues terribleonexx88 5.0 Mustangs 8 December 4th, 2006 11:40 PM
86 Jeep Starting Issues... 97Cobra All Other Vehicles 1 July 1st, 2006 09:01 PM
