wiper arms....
Old January 19th, 2009, 12:44 PM   #1
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
wiper arms....
how do i get this thing off? i want to clean and paint my faded cowl panel, but i can't get the darn wiper arm off. do i need a certain tool to get that clip out?
thanks
i have no mustang. so don't listen to anything i say.
Old January 19th, 2009, 12:45 PM   #2
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
Eats Chevys, Shits Imports...
Grabber523 has a spectacular aura aboutGrabber523 has a spectacular aura aboutGrabber523 has a spectacular aura about
Should be able to do it with a fingernail... Can you hook it with a small screwdriver?
http://www.moddedmustangs.com/forums...p-vote-me.html
TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER)
MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER
TRUNK MONKEY CREW FOUNDER
Old January 19th, 2009, 12:46 PM   #3
87gtmustang's Avatar
1987 mustang GT
87gtmustang is on a distinguished road
Send a message via MSN to 87gtmustang
idk im wondering the same thing i was going to paint that and the wiper arms
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump
and more to come
Old January 19th, 2009, 12:47 PM   #4
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
i can get it out a little. should the arm just lift right off after getting out about 1/4 inch? or does the clip need to come all the way out? cause i tried to pull the arm off with the clip pulled out as far as i can get it. but it won't budge.
Old January 19th, 2009, 12:53 PM   #5
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
i got it. just had to pull the clip out and give it a little elbow grease. but the arm finally came off. thanks for the help.
Old January 19th, 2009, 04:36 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
Easy way for future reference.. Pull and hold the wiper as far from the windshield as it will go, pull out and hold the little clip and bring the wiper back towards the window until it stops (it will stay up off of the windshield when it hits the clip). You can now let go of everything and just pull and wiggle the base and it will pop right off.
Old January 19th, 2009, 05:13 PM   #7
ryans88gt's Avatar
^^ true...
also be careful if you have a cowl hood
Old January 19th, 2009, 09:50 PM   #8
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Originally Posted by ryans88gt View Post
^^ true...
i do. but it wasn't really an issue. i was doing it right to begin with. but there's no telling how long those things were on there without being removed. it just took a little convincing to work it loose.
Threads Similar to: wiper arms....
The $2 Wiper Delete DanTheMan Visual 16 April 18th, 2008 10:59 AM
How do I take the wiper cowl off? Mike Johnson V6 Mustangs 3 March 5th, 2008 10:05 PM
HELP!!! Wiper motor Stang281GT 99-04 0 February 19th, 2008 06:49 PM
QA1 Tubular Control Arms (A-Arms) keith0s 5.0 Mustangs 3 October 19th, 2007 11:20 AM
Steeda lower control arms (Trailing arms)? kmjsmith 2005 - 2010 6 July 4th, 2007 04:59 PM
