What is the Biggest cam with 202 valves on stock pistons
What is the largest cam I can run with a 202 int valve and stock pistons in a 1989 5.0 block with 1.6 roller rockers.
Depends on what heads you use. Either way I would highly recomend checking valve to piston clearance. 10 minutes checking the clearance will save you weeks and months of time down the road, not to mention saving you a ton of money.
1990 LX hatch
smaller than stock. 1.94 is the max valve size you can use without notching the pistons on a stock bottom end.
#4 | |
Unless you run a Twisted Wedge head.
#5 | ||
Moderator
There's a reason Ford codenamed them the Terminator
I bought the twisted wedge heads they are the track heat heads with 202 160. So how big of a cam can I run with 1.6 ratio rockers?
Moderator
i woudlnt go bigger than a trickflow- 224/232 .542"/.563" (@.050) cam, its susposed to work well with the TW heads.
Moderator
even with that make sure you check your ptv clearance.
Threads Similar to: What is the Biggest cam with 202 valves on stock pistons
| biggest tire on a stock 17 | RedStangGT | 99-04 | 23 | August 19th, 2010 08:36 PM |
| cams with stock pistons | Badasstang281 | 99-04 | 18 | November 25th, 2007 10:07 PM |
| valves | mpboy | 2005 - 2010 | 2 | September 4th, 2007 03:05 PM |
| Will 2.02 Valves Clear Stock Piston? | 95StangSVT | 5.0 Mustangs | 1 | September 30th, 2006 01:37 PM |
| IAC VALVES | stang fanatic | 5.0 Mustangs | 3 | May 24th, 2006 10:56 AM |
