How do you remove the injectors?
I don't want to break anything, those suckers aint cheap! . . . .
I'm replacing the upper and lower so I need info ASAP!
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1990 LX hatch
Dont yank them out. clean with carb cleaner, spray some blaster on em, then tap them out GENTLY, from the ports with a bolt. Or you can yank them and buy new pintle caps.
thats what i was thinking, so i'm assuming that they are just kind of corroded in there like everything else on the engine?
1990 LX hatch
Yes, they will come out tho. The cleaner the hole for the inj. is the easier it will be.
1982 GT t-top
no proof of purchase
Whatever you do don't just yank violently you will break something
1993 5.ohhhh
12.97 @140mph
unplug the wiring harness from the injector, then twist them left and right until they wiggle out. If your injectors are stuck that is gross lol.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
thanks guys
I don't do anything special, I just pull them out. Been doing it for almost 20 years now with no problems.
will 42's and a matching maf do any harm to put in now before i do the stroker?
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
here's a trick we used on my turbo coupe to take them out with out damaging the o rings jerking on the injector.... we just grabbed the fuel rail and pulled up to get them all to pop out at the same time then took and old plug wire and pushed it up around the injector, and pull it out using it like a spark plugs...sounds dumb but worked like a charm.
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
bump
48.47@ 12.58
not if your ecu is tuned for it.
if you swap injectors without a tune you chance ruining your rings. |
guess i'll just hold on to them for a while then, no use in getting it tuned twice
#15 | |
1992 Lx
11.39@119.24
my car was running an af ratio of 10-1 before my tune with my 24lb injectors and matching pro-m maf, i could imagine the 42s would be alot worse
1994 GT
yea its cake..jus pull them strait up, and they should jus pop out
Cohagan Engineering, Inc. |
It will probably start hard and might run a little rich. I wouldn't bother putting them in now because they will offer no benefit with your current combo.
#18 | |
48.47@ 12.58
something wrong with what I said?
To my understanding ( and exp.) if you run bigger injectors without a tune your car will run rich. When you run rich you chance harming your rings because the extra fuel is washing off the oil leading to premature failure. |
thanks again for the help
Threads Similar to: How do you remove the injectors?
| how do i remove this? | BWAL | 5.0 Mustangs | 3 | April 22nd, 2008 03:35 PM |
| How to remove. | stang94 | 94-95 | 2 | March 18th, 2007 08:29 AM |
