#21 |
85 GT/86 SVO/2010 GT500
Can I ask why you want to know the stock cam specs?
#22 |
or pay a machine shop 30 bucks to drill tap for the comp 30-1000 retro fit kit
#23 |
Because i dont know if Summit SUM-K4400 - Summit® Cam and Lifter Kits - summitracing.com would be a decent upgrade or what kind of difference it would make
1995 Nissan 240sx. Coilovers, intake, full 3in exhaust, RUCAS, J30vlsd, 1 piece drive shaft, Q45 Front brakes, short throw, subframe collar bushings. |
#24 |
thats prob not much bigger than stock lift wise, duration will be more
#25 |
that is dual pattern cam you stock cam odds are the intake abd exhaust lift are the same , Fords need more exhaust lift to help with the small exhaust valves. That cam is more like a RV cam it doesn't make power over 4000 rpm
#26 | |
Getting a little old Not to be thread jacking either
#27 | |
1992 Lx
11.39@119.24
hahahah shifting at 4k would be boring as fuck
#28 |
87 Coupe
![]() iTrader: 3 reviews
I do plan on makin more than 400HP.......ok so is it easier to just buy a swap kit or piece it together separately? I do plan to have head work done, and make it a roller and throw a bigger cam, etc, but just want what I need now to get it driveable/movable. I don't need to change the distributor or pulleys right?
Eats rice daily
#29 |
Trust me it is boring as hell, and almost costing me races if it wasnt for good launches xI
#30 | |
The Razor's Edge
#31 |
87 Coupe
Will down the road. when I say I HAVE to have it moveable I mean it. It has to be off the lot I have it in soon and the only place I can park it for now said it has to be able to drive back an forth at least so they can move it if needed.
Eats rice daily
#32 |
The Razor's Edge
word
Threads Similar to: 351w
| 351w? | whiteboycustom | 5.0 Mustangs | 8 | March 25th, 2008 02:05 PM |
| 351w | dragpipe | General Tech | 2 | May 2nd, 2007 07:53 AM |
| 351w | mustangrebuilder | Classic Mustangs | 5 | April 2nd, 2007 08:19 PM |
| 351w | FastBack71 | 94-95 | 6 | February 4th, 2007 03:40 PM |
| 351w | terribleonexx88 | 5.0 Mustangs | 11 | December 31st, 2006 01:08 PM |
