Early shifting aod
Old January 28th, 2009, 03:17 PM   #1
yamadog is on a distinguished road
Early shifting aod
I have a 1990 mustang. Car has most basic bolt ons.....Full exhaust, full intake with 24 lbs injectors, 3.73's. I got the car after it sat for about four years unused. Trans was rebuilt about a thousand miles before the car was parked. When in drive, it'll shift around 1500 in each gear unless it's floored, then it'll shift around 4000. It does fine when shifted manually, but man, if left in drive, i'll be in third before crossing an intersection from a stop. Is this normal, or is something wrong? And more importantley, can it be adjusted at home? I searched and didn't find anything helpful. Thanks, Jason
Old January 28th, 2009, 03:31 PM   #2
black5.0's Avatar
90 mustang notchback
black5.0 is on a distinguished road
I'm pretty sure mine shifted at 2000 rpms or something like that.
306 Turbo Notch D&G Tuned
1999 Chevy Silverado 5.3
Old January 28th, 2009, 04:31 PM   #3
2002BLGT is on a distinguished road
Send a message via AIM to 2002BLGT Send a message via Yahoo to 2002BLGT
yes its normal , the gears are making the effects of the early shifting worse , get a shift kit in it and it should help , as well as a good stall
Old January 29th, 2009, 06:02 AM   #4
haywood11's Avatar
1988 mustang lx
interior torn out!
haywood11 is on a distinguished road
Send a message via Yahoo to haywood11
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD.
Plans: full black interior, black paint and supercharger???
Old January 29th, 2009, 10:43 AM   #5
91 LX
13.7@101
yeah you'd be surprised what a shift kit would do for you
Old January 29th, 2009, 05:02 PM   #6
The Razor's Edge
White Thunder's Avatar
dont forget about the inaccurate stock tachs
founder of the FTN Club
Old January 29th, 2009, 06:41 PM   #7
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
well thats the basic nature of a AOD, if i where you i would double check the tv cable, if you need help on how to adjust it let me know.
Old January 29th, 2009, 06:43 PM   #8
78mach1's Avatar
if you go with a shift kit avoid the b&m, its junk, transgo is a good way to go.
Old January 30th, 2009, 05:23 PM   #9
Ya, if you don't mind, I'd love help on the tv cable....I'm new to mustangs and there idiosynchracies..... Thanks, Jason
Old January 30th, 2009, 07:13 PM   #10
342pony's Avatar
Looking right now
342pony is on a distinguished road
AH,swap in a 5-speed...
Old January 31st, 2009, 02:22 AM   #11
78mach1's Avatar
dont listen to this fool
Old January 31st, 2009, 02:38 AM   #12
78mach1's Avatar
here is a detailed way to do it without a guage, you can usually get it pretty close with this procedure.
Ford AOD Transmission
also here is a artical called "how do i make my AOD run with the 5 speeds"
great article
Dugger Racing - Mustangs and a whole lot more!
Threads Similar to: Early shifting aod
manual shifting AOD BWAL 5.0 Mustangs 41 May 18th, 2010 03:58 PM
Early shifts smccoy916 99-04 5 July 25th, 2008 05:04 PM
It's NEVER too early homebrewed The Clubhouse 13 July 14th, 2008 08:45 AM
Santa Came Early! 95StangMX 5.0 Mustangs 17 December 21st, 2007 08:49 AM
Little early, but I don't care. Cricket The Clubhouse 5 October 22nd, 2007 09:03 AM
