i know i know... but help is needed
Old January 29th, 2009, 05:21 PM   #1
1997 Mustang GT
N/A
samuel642000 is on a distinguished road
i know i know... going carbed need help
ok like many others i have decided to go carbed. main reason is the person that owned the car before me did a real hack job on the wiring harness of the car and now i have little problem that need to be fixed or removed. so i did a search and think i have everything i need for the swap could someone put some input in to as if i need something else OR an solution to my messed up car???
!. intake and Carb
2.85 dizzy
3. i plan on going the cheap rout and taking out the stock fuel pump and putting a piece of hose in the tank, or a sump havent decided
4. holley blue fuel pump
5.return style regulator
that should be about it right?
any input would be greatly appreaciated.
Old January 30th, 2009, 01:23 AM   #2
GT87Stang's Avatar
1987 Mustang GT
GT87Stang is on a distinguished road
throttle cable or just do what i did and make your own bracket.... plug wires.... duraspark box... think i paid 125 for dizzy, small cap, rotor, and box from autozone..make sure to the dizzy for a 85 5 speed for the steel gear... need any help let me know... while its still fresh on my mind....
your running same setup i am... holley blue is loud as hell too lol
1987 Mustang GT
World product heads
Triflow Stage 1 Cam
Parker Funnel web 650 DP
Eagle Rods with forged pistons
T5 with 373's
Old January 30th, 2009, 07:11 AM   #3
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
If you have the time and money just go ahead and put sump in your stock tank and run your fuel line that way
Old January 30th, 2009, 12:23 PM   #4
1997 Mustang GT
N/A
hey thanks man, one question which wires do i remove after i take out the efi? oh andi know all about the blue pump i have one on my Cummins
Old January 30th, 2009, 02:27 PM   #5
86er's Avatar
fyi, dont waste the extra money on a return style regulator, blue doesnt flow enough to warrant a return line. get you a 15 dollar summit style reg and be done with it
Just a truck
Old January 30th, 2009, 04:46 PM   #6
1997 Mustang GT
N/A
is there anywhere i can grab on of these instead of ordering it? like autozone or something?
97 GT, a project I guess you could call it
MILITARY CREW AT3
Old January 30th, 2009, 04:53 PM   #7
86er's Avatar
no, but hell shouldnt take but a day or two to get one, or find a local speed shop, something like that should be on their shelf
Just a truck
Old January 30th, 2009, 10:42 PM   #8
GT87Stang's Avatar
1987 Mustang GT
there is two seperate harnesses on these cars... just remove the one that goes to the computer. unless u have a/c then u have to cut apart ur harness.
1987 Mustang GT
World product heads
Triflow Stage 1 Cam
T5 with 373's
Old January 31st, 2009, 12:50 AM   #9
89LX347's Avatar
89LX347 will become famous soon enough
heres a little before and after shot of mine, maybe you can get some ideas of what you need.
heres a list of what i can think of
1.A1000 pump (got a good deal on it)
2.bought in in tank sump style thing, looks like the old fuel pump but with 2 AN fittings on the top.
3.Aeromotive reg. (with the holley blue you dont need a return line, you can just do a dead head system)
4. carb
5. intake
6. fuel log for carb
7.throttle cable (lokars comes with a braket)
8.return springs
9. filter
10. misc. fuel lines and fittings
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old January 31st, 2009, 01:12 AM   #10
GT87Stang's Avatar
1987 Mustang GT
did yours run better after the carb setup?
1987 Mustang GT
World product heads
Triflow Stage 1 Cam
T5 with 373's
Old January 31st, 2009, 01:30 PM   #11
89LX347's Avatar
mm yes and no, i also put tubular front suspension on it during the swap. got it running. and then sold it. never really got to g all out with it
Threads Similar to: i know i know... but help is needed
what all is needed?? Iownastang 5.0 Mustangs 6 October 24th, 2007 01:44 AM
HELP needed in NJ jersey98gt Northeast 3 August 21st, 2007 05:54 PM
Help needed CNASHGO The Clubhouse 0 March 27th, 2007 01:43 PM
Help Needed XxMUSTANGxX V6 Mustangs 34 February 19th, 2007 10:13 PM
What's needed?? 2ndChildhood 94-95 3 December 3rd, 2006 11:49 PM
