bubbling radiator ?
Old January 29th, 2009, 07:19 PM   #1
stfudvs's Avatar
302 5.0
stfudvs is on a distinguished road
bubbling radiator ?
there is some smoke if the car runs a long time or i run it to hard but the smoke is only around the radiator and its resivior, and the resivior begins to bubble and growl
the resivior is leaking and the radiator may be leaking too
is it possible it may not be a head gasket problem
im sure there is also no pressure in the coolant resivior
also i cant seem to get the cap off the radiator it feels stuck on there, it turns to vent but doesn't seem to want to twist off
any idea on what i can do?
im going tomorrow to track down a new resivior that seals and doesnt leak, a new tube for it and a new radiator cap hope that fixes it, maybe i will need a new radiator ?
if you were on a bicycle and we were going up hill i could beat you in a race
Old January 29th, 2009, 07:47 PM   #2
86er's Avatar
take the radiator cap off, let the car warm up, if it bubbles, head gasket problems, if it doesnt problems else where
Just a truck
Old January 29th, 2009, 08:45 PM   #3
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
I take it that it is steam not smoke, Go to autozone and get a pressure tester for your radiator pump it up look for leaks, and check oil to see if any coolant has got in it.odds are it's not your head gasket if it is steam comming from the radiator
Old January 31st, 2009, 09:00 AM   #4
stfudvs's Avatar
302 5.0
i bought a new radiator cap, bought a new coolant resivior, ran new tubbing, flushed the radiator and cleaned it out the best i could, refilled the fluid and now its fine, ran it hard yesterday to see what it would do and was good all day
Threads Similar to: bubbling radiator ?
Radiator blackfox 96-98 4 August 10th, 2008 10:37 PM
Radiator V6boi V6 Mustangs 12 October 30th, 2007 02:23 AM
Radiator javier351lx 5.0 Mustangs 2 July 11th, 2007 04:31 PM
radiator the68stangdude Classic Mustangs 4 July 1st, 2007 03:52 AM
Bubbling Antifreeze Tony_90fox 5.0 Mustangs 37 November 14th, 2006 04:13 AM
