buying a new used engine
Old January 30th, 2009, 10:27 AM   #1
1985 Mustang GT
viperlocc is on a distinguished road
tomorrow im going to go pick up a fully rebuilt 306. has 300 miles on it. he said it has a HO cam but doesnt know the specs so i dont know if its from an HO motor or a cam that is better than stock. but of course, ive got some questions:
Im gonna transfer my cam from my old motor to my new motor and use the same pushrods in the same location as they were in the old motor. heads will be transfered over too once they are back from the shop. Do i have to re-break the cam in (sit their for 15 min at 2000 rpms)?
the engine sat for the winter season in a garage. when i pull the heads ill dump a little oil in the pistons and hand crank it over a couple times. is this a good idea?
what are things i should look for when picking up this engine?
Old January 30th, 2009, 10:35 AM   #2
No need to put the push rods in order.....no break in time on the cam.
PeteAndersonRacing.com
Old January 30th, 2009, 11:16 AM   #3
1985 Mustang GT
are you sure? when i removed the heads, my haynes manual said to mark them in the order they came out so when i put them back in they go in the same spot i thought this was for any wear and tear. but i have roller rockers so i guess it doesnt matter seeing as ill be adjusting them...
i think i answered myself...lol
Old January 30th, 2009, 12:04 PM   #4
91 LX
13.7@101
what cam and heads are you putting on the 306? and what heads are on the 306 now?
Old January 30th, 2009, 12:40 PM   #5
1985 Mustang GT
stock heads as far as i know. the cam I have is a E303, and the heads are Windsor Jr.
heads are going to the shop to get cleaned up and check out, possibly a little machine work just to make it flow better, nothing to special.
Old January 30th, 2009, 01:48 PM   #6
91 LX
13.7@101
scrap the E303 while your at it
Old January 30th, 2009, 02:00 PM   #7
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
No break in on roller cams. No particular reason to worry about push rod position as long as they are all in good condition. When I disassemble valve trains I usually do maintain part orientation but it sounds like your using some from here some from there so it won't matter they will be mixed up anyway.
Never fast enough.
Old January 30th, 2009, 02:05 PM   #8
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
+1
odds are you will be happy with the E cam, good low end power and they sound good
Old January 30th, 2009, 03:43 PM   #9
1985 Mustang GT
thats all i want. not looking for big power yet. gonna stick money into the 351, just not sure what to with it yet.
i thought about a different cam, but when the cam was in the running 302, i like it. had the perfect sound and better than stock power.
Threads Similar to: buying a new used engine
buying a treadmill is like buying bottled water obdnanr The Clubhouse 18 August 3rd, 2008 10:55 AM
buying a treadmill is like buying bottled water obdnanr The Clubhouse 9 August 2nd, 2008 12:47 AM
what to look for when buying? mustangfu 94-95 21 March 30th, 2008 12:03 AM
Buying a 95 GT 969800gt 94-95 10 January 25th, 2008 11:58 AM
buying a used engine 69_5.0_stang V6 Mustangs 2 May 7th, 2007 02:55 PM
