#41 |
maybe the distributor you put in took a crap ? was it a stock replacement ?
#42 |
thats exactly what I was thinking. you never know what you're going to get with new parts these days
#43 |
Yeah it is a stock replacement? Would the dizzy make it rev alot higher at idle? I can see how it would cause it to miss up top and act like it is dumping fuel and missing. I just bought a new IAC i am going to put it on tomm when i am off work and see what happens. Also, if i take off the tps and put it back on would it mess anything up? Does it need to be adjusted at all?
#44 |
SVTfocus, F250
the IAC will only change things at idle. it shouldn't make a difference anywhere else.
and you would have to readjust the TPS but its pretty simple if you have a digital mulitmeter |
#45 |
#46 |
SVTfocus, F250
5.0 Base Idle Reset
the optimal voltage is .989 i believe but i dont think it will make a very noticeable difference as long as you are in the range |
#47 |
Before i go and do all that can I check the tps voltage as the car sits now and see what it is at, would that check what it has been running at last time I drove it? or does it reset?
#48 |
SVTfocus, F250
just follow the steps do check tps voltage you dont need to do everything on that list. and if you dont move the TPS the voltage should not change
#49 |
I bet your Distributor is off a tooth.
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
#50 |
weeee foooord!
#51 |
I'm leaning toward... I'm leaning toward... You hold the steps..
I need to know and be accurate and seat of the pants dyno my questions if you will: 1. Does the dizzy throw a code? Say Yes or No or write like me or y/n me. 2. Is this the notorious 'dizzy' tied to the 02? Yes or no? 3. If 'no' WATT is the dizzy tied to? 4. At the time of the dyno tune was the car runing like the baddest maddest thing on the street, you received a super good tune or you felt no difference. Mileage stayed the same if you matched say before the tune now after the tune? Yes, big change. No, slightly higher but not what I'd call is up my friends and rave I can squirt the tires at will. 5. This is the 'be accurate' part... Will that thing run like crap from idle to like mid throttle, but at mid throttle to wide open throttle, it runs like the dyno tune again. Seat of the pants yeah, something like that, or no, that thing won't budge the faster I go it gets worse is details, are those the details like if I test drove it now? 6. More like I want to hear you say what 5 sorta said: Runs like shit on the bottom, hauls ass up top. Yes Or No? |
#52 |
1993 Mustang GT
If those plugs that you put in were new, and are now covered in fuel or something else, that could be a problem not related to your computers.
#53 |
I have been at work all day and have not been able to touch the car yet. Hopefully i will get some time tommorrow. I am going to pull some plugs and look at them. When my dizzy went out and i put the new one in, the car ran fine and like 3 weeks later i was driving at school and it just started acting weird. After the tune the car ran freaking amazing. The driveability was outstanding and never had any troubles with it until the dizzy went out it seems like shit started to go out, and fast. it runs kinda ok at idle to mid throttle and up top it will miss, but it also misses some down low. I have no idea what it could be.
#54 |
Oh and in the other thread started about the intake for sale and stuff, that is my buddy who asked me if he could post about that thing. So yeah dont hate me please. I love this website, there are always people willing to help when i have a question.
#55 |
return the distributor
#56 |
well its at the shop now and will be looked at on wednesday so hopefully they can fix it and it wont cost alot.
Threads Similar to: Car runs like......!!!
| need help car runs rich?? | worlz08 | 5.0 Mustangs | 4 | December 2nd, 2008 08:48 PM |
| Car runs like POOOOOOO.... HELP! | 00SoSlow | 5.0 Mustangs | 12 | November 5th, 2008 12:34 AM |
| Car Runs Like Crap | 1bad5.0 | 94-95 | 9 | January 15th, 2008 03:38 PM |
| car runs like a bucket | shadow98gt | Modular Mustangs | 5 | June 6th, 2007 09:56 PM |
| Car runs rough | chase | 5.0 Mustangs | 8 | December 24th, 2006 07:44 PM |
