9 in rearend?
i have this question in another topic but i wanted to repost it incase others didnt go into the conversation from the previous topic. im planning on getting a 9 in moser "bolt in" rearend the question is will the typical (adjustible) suspension components work that would work on the 8.8?if not where can i find suspension componenets for the 8.8?
i u buy a direct bolt in for ur car...everything should swap over
1995 GT::Sold! Looking for another stang... |
buy the direct bolt in. this way you dont have to have the housing narrowed get new axles and it will bolt right up to your car
bracket racing sucks |
cool thanks yall
Keep in mind that you are going to be adding at least an additional 60lbs of weigth to your stang with that. just FYI.
#6 | |
#7 | |
As Darrell stated, unless you are making big power you can get by with an 8.8" rear. It's much lighter and easier on the wallet IMO. Give TeamZmotorsports a call - I think you can get an entire housing for roughly $700.00 not trying to steer you away from the 9" rear, but just giving some food for thought. Hope this helps, and good luck. |
#8 | |
1987 Mustang LX
13.9@102.43
[/quote]As Darrell stated, unless you are making big power you can get by with an 8.8" rear. It's much lighter and easier on the wallet IMO.
Threads Similar to: 9 in rearend?
| What rearend does my 89 gt have | White 89 | 5.0 Mustangs | 5 | October 4th, 2007 04:56 PM |
| Rearend ?? | Stang6899 | V6 Mustangs | 6 | September 21st, 2007 06:47 PM |
| rearend-tranny ? | theyanks904 | V6 Mustangs | 130 | August 15th, 2007 06:29 PM |
| what rearend should i use? | etony89 | 5.0 Mustangs | 26 | May 26th, 2007 07:59 PM |
| Rearend | thewayshemoves | 99-04 | 6 | December 27th, 2006 11:31 AM |
