1989 Mustang GT 5.0
IRS in my 89 5.0 GT
what would be the easiest swap for this to be done, from a 03 cobra or the f150 lightning ?
im getting into autocross and open track SCCA / NASA stuff and i really want to my stang to handle, any tips or ideas im want to use maxium motorsports for lots of chassis and suspension
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
89 GT, 92 LX
Your only option is the Cobra. Lightnings dont have IRS.
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
thunderbird super coupe is also an option.
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
the best way to do it is an 03-04 cobra irs swap.the reason is its the strongest factory IRS that will fit your car.the supercoupe setup is different than a mustang so only the
8.8 centersection will fit,your other option is the 99,01 cobra but that setup isnt quite as durable as the 03-04 irs.
thunderbirds I thought had the 7.5 in the irs
The Razor's Edge
the old ones did
start looking for a wrecked cobra in junk yards |
no sir....
lincoln mark VIII has IRS and tbirds too
the v6 t-birds had 7.5 irs but the v8s and SCs had 8.8s but that wouldnt work for your swap
The Tbird IRS will not bolt up for a fox-chassis car. The 99-04 Cobra IRS is a plug and play swap, everything bolts right up with no real heavy modification needed.
And if you're looking to make it handle, keep the solid-axle and start talking to Maximum Motorsports or Griggs Racing. There hasnt been an IRS prepped mustang yet that has been faster than the solid axle cars that are done right. |
#10 | |
I'd keep the solid axle and throw in a tri-link or some such solution.
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
1989 Mustang GT 5.0
i want to use maxium motorsports for like everything, but how can u be serious the the live axle out handles IRS, i find this hard to believe, live axle is old skool technology i would amagine IRS performing hell of alot better, think of all he BMW M3's and evo's and impreza's how could the live axle rear end compare to IRS?
You may can find someone that has swapped the IRS out of an 03/04 cobra and just buy the IRS from them. I know alot of people around Memphis has had the swap done in 03/04 Cobras to a live axle and thier old IRS is still sitting around somewhere.
#14 | |
go with one from a terminator cobra like stated above, those guys remove them because they break em and you do know you'll be adding like 400lbs to your car right
89 GT, 92 LX
#17 | |
In general, yes, an IRS is better than a stick axle. However, the IRS in the mustang was designed around a chassis that was designed for a Solid Axle, making it a very compromised design. A properly setup solid axle car will handle amazingly. Bruce Griggs has been proving that since the early 90's. As far as the live axle comparing ont he race track, it does so quite well. In 2008's Ultimate Track Car Challenge put on by Grassroots Motorsports, there were two solid axle mustangs in the top 10. One of which was on pace to destroy the fastest time of the event before he had an off and broke his car. Ernesto Roco placed 3rd with only one single lap in a solid axle griggs prepped car. |
1989 Mustang GT 5.0
So the live axle is hands down better for autocross, open track, drag, street than IRS...i still cant get that, when was the last time uve seen an indy car is a live axle setup, and the IRS is heavier than the live axle?
1989 Mustang GT 5.0
im still thinking of converting to IRS, i mean it all sounds good with a beefed up live axle but if u take physics into mind and the geometry of suspension and suspension travel while going around a corner, or even just cruising on the streets, im looking at maxium motorsports things for IRS and you could build up a cobra IRS just like you can the live axle...
2002 Gt
Not Slow
![]() iTrader: 1 reviews
at best, more of a novelty in your vehicle,... the solid axle drivetrain on these are no slouches as many of these gentlemen stated, you can have quite the solid axle autocrosser with a little money and work
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
Threads Similar to: IRS in my 89 5.0 GT
| IRS on a 96 GT | HBK_2007 | General Tech | 27 | July 10th, 2008 03:25 AM |
| non-IRS? | RanGer498 | 99-04 | 11 | March 4th, 2008 11:10 PM |
| IRS on 99/01? | AndrewA. | 4V / SVT | 7 | February 7th, 2008 08:51 PM |
| IRS | JaxnsGT | General Tech | 2 | October 19th, 2007 12:46 AM |
