Coolant leak... any ideas?
So I just got a "new" '91 LX hatch... the car runs great. I put damn near 100 miles on it today and went to dinner. When I left the restaurant, the temperature went up to around 220*. When I drive it though, the temp goes down. At stop lights, it goes back up.
When I got home I popped the hood, with the engine off, and heard a hissing sound coming from behind the intake manifold, on the throttle body side. I can't see where it is coming from, but I don't feel any water coming out of the head on that side. Any ideas? Last edited by astras; January 31st, 2009 at 10:07 PM. |
1994 GT
check ur cooling fan
Cohagan Engineering, Inc. |
there are coolant lines that run to the egr spacer you should check
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
Just a side note, I just checked the oil and coolant... There is no oil in the coolant and no coolant in the oil.
how low on coolant?
does it has the clutch fan? look for oil on the clutch....never let it get that high I hope you turned the heater on
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
Like I said, as soon as I started moving, it went back to normal operating temperature... the hiss was definitely water coming out though. There was a small puddle under the car. I am pulling the intake tomorrow and replacing the gaskets. I will inspect further then.
you don't need to replace any gaskets at this point....check the TB coolants lines..
clutch is bad in fan
check the weep hole on your water pump.
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
did you check the lines that go to the heater core? they seem to blow on every car that I have had in the passed 10 years.
1992 Lx
11.39@119.24
prob has underdrive pulleys makin it run hot cold hot cold once you get some air on the radiator, and its prob the lower intake mani leakin water
Threads Similar to: Coolant leak... any ideas?
| coolant leak | SilverFreakGT | 99-04 | 1 | January 26th, 2009 08:55 PM |
| Coolant Leak | 98stangv6 | V6 Mustangs | 1 | April 20th, 2008 04:41 PM |
| coolant leak? | shadow98gt | 96-98 | 3 | May 14th, 2007 02:59 PM |
| Coolant leak? | shan | 96-98 | 12 | April 26th, 2007 08:52 AM |
| Coolant Leak Help | garyvang | 5.0 Mustangs | 13 | May 11th, 2006 10:55 PM |
