heater core
well i replace my heater core about 1 month ago and its been working good enough to keep me warm. but last night when i went to pick up my friend i started smelling anti freeze. so when i got there i stoped the car and looked on the passenger side and the floor was wet.
looks like im going to by pass the heater core now. its a shame bc it took me some time to replace it and im not going to do that again
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump and more to come
that sucks. thats a hell of a job to have to do twice
hahaha that y im saying im going to bypass it. gotta go to abc to pick it up the piece which also suck bc its 30 miles away to the closest store that would sell it
#4 | |
I Post Entirely Gay Too Much
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
Dont you need defrost? When you replaced it did you go with a ford one or the cheap one from autozone?
it was like 26 bucks and either from autozone but i think it was from o riellys
#6 | |
Dont make the same mistake again. Go to a ford parts dealer and get the original ford part. I bought one from autozone and checked around and everyone on here said get a new ford one. I compared the two and the ford was a shit ton more heavy duty.
12.9 @ 105
You might one to try it again one you get an estimate from a garage. It's much easier the second time.
Atomized
yeah i've had the pleasure of doing a total of 4 now, one for my car and the other 3 were for friends. I used the ford one and it really is better. The second time really is alot easier.
yeah the 2 time should be easyer but i still dont think im going to be doing that anytime soon
Can you still use the AC if you delete the heater core? I don't need the heater 'cause I live in a hot country so I wouldn't mind the weight saving. How much does the heater core weigh?
![]() 244whp/284wtq Mod list in My Garage |
na, they're 2 seperate systems. but the weight savings isnt going to be much with that heater core.
The Doctor
'01 Cobra Vert.
+1
not much at all mayb 2 lbs
1988 GT
I abandonded my heater core long ago. But for convirsation sake, where is it located? And how hard is it just to take out, not to replace?
1989 LX Vert - 1993 Notch
Fast
They are behind the dash. Basically have to pull the dash out.
Not hard per-say, just a time consuming PITA Next time I do mine I'm going to try and fit a 96-02 core in mine. They are almost the same size, but made of Aluminum instead of Copper.
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
2000 mustang GT
+1 on the aluminum one
No bucks, no Buck Rogers
One thing I learned while pulling the dash out of a 2.3 car and a 5.0 car, (5.0 swap)... Dont take the large plastic dash part off of the metal dash framing. Take the entire assembly out. That way your wires stay on it and there are less pieces to put back on... less headache in the long run.
After you get the dash out, the heater core is inside the big black air box.. I didn't replace my heater core when I had the dash out, so I dont know how to take it out of the box. And +1 on the person who recommended the Ford heater core. Those auto zone/oreillys parts are cheap knock offs at best, and for something this hard to replace, personally I would pay a little more for a better part so I wouldn't have to do it again..
'87 2.3 Notch with +4 cylinder mod ![]() MM's Resident Aggie Black Stang Crew Member #11 |
Threads Similar to: heater core
| Heater Core.... | jim2029 | 5.0 Mustangs | 5 | June 22nd, 2008 11:34 PM |
| heater core | ThE GhOsT RiDer | 5.0 Mustangs | 3 | February 2nd, 2008 03:47 PM |
| Heater Core | ks_emt | 2.3 Mustangs | 6 | November 26th, 2007 11:51 PM |
| Heater Core! | ujslost | 96-98 | 13 | November 18th, 2007 07:59 PM |
| heater core | JABES | 5.0 Mustangs | 6 | December 5th, 2006 12:26 PM |
