Dumb 351w Question. - Page 2
Old February 2nd, 2009, 07:01 PM   #21
86er's Avatar
Originally Posted by r.barn View Post
1 3/4 Long tubes min.
BBK makes a nice set of swap headers
thats what I have on mine, not bad, had to slightly tap on the header on the driver side to clear the steering linkage, but other wise they fit great.
Darrell may only run 5, but my old roommate has a 7 qt canton with the deeper sump and kick outs its close, but doesnt touch the crank, did some off the car fills, measure how far down the crank would be etc to come to that conclusion
Just a truck
Old February 2nd, 2009, 07:06 PM   #22
shadowgames81's Avatar
87 Coupe
shadowgames81 will become famous soon enough
So the lt's are that much better?? I guess I'll try an save up for some then if thats the case. Glad the bbk work cuz they are the cheapest I've found lol. If at 339 you can call that cheap.
Eats rice daily
Old February 2nd, 2009, 07:47 PM   #23
87 Coupe
Can anyone point me to a place where I can find out about using the 351w ignition system for the 87 bronco I pulled it out of??
Eats rice daily
Old February 2nd, 2009, 07:48 PM   #24
87 Coupe
wanna keep it carbed and run that if at all possible
Eats rice daily
Old February 7th, 2009, 09:33 PM   #25
87 Coupe
I was reading somewhere that other vehicles w/ the 351w had the oil pan I could use. Is this true? Someone said a bronco pan could be used, is that right??
Eats rice daily
Old February 8th, 2009, 02:44 AM   #26
89LX347's Avatar
89LX347 will become famous soon enough
Originally Posted by 86er View Post
um in the 7qt you run 7, it has more room at the bottom of the pan to keep the oil away from the crank........
we run the ford swap pan on severy mid to low 10 sec cars and have no problems, we actually put 6 in the ford pan
you can run 5 or 6 in the 7 quart pan just as long as your pickup tube is near enough to the bottom. i am kinda anxious to see your car. do you have any pictures? do you have 2 plate systems on your car? fogger system?
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old February 8th, 2009, 03:04 AM   #27
86er's Avatar
Ive got a small intro thread on here with some build up pics.
its got a two stage plate system 75 on the first off the two step and 200 on the shifter.
nothing fancy.
vic jr top end 750hp carb 9:7.1 motor c4 man valve body and brake
right now its got a baby cam 228/228 .584/.584
the biggest help is the cars weight, 29xx with my 280 lb fat ass in the car.
the 86gt is gone, and its now an 86 coupe
link on the thread here with some build pics,
sorry for the hijack
Just a truck
Old February 8th, 2009, 03:32 AM   #28
87 stang + 97 ranger
both combined i can't break 15 secs.
Cool Bam is infamous around these parts
I got a windsor sitting up in my garage. Too bad I know nothing about them yet.
Old February 8th, 2009, 03:19 PM   #29
89LX347's Avatar
nothing fancy.
thats pretty darn clean.. im guessin its not done and you havnt ran it?why such low compression?
Old February 8th, 2009, 04:08 PM   #30
86er's Avatar
its a pump gas motor.
it went 10.70's breakin up on the second stage, got that fixed, and wow what a difference it is to be able to keep the foot planted the whole time. Now the car is down again, getting a 10pt cage, kirkey seats and manual brake swap and a new cam
242/248 .605/.630
Just a truck
Old February 9th, 2009, 12:39 AM   #31
89LX347's Avatar
242/248 .605/.630
thats pretty good. what was your 60ft?
well 10.5 is a pump gas motor also. i was just seeing if you had planned to boost it in the future?do you have flat top pistons?
i just bought kirkey seats for my car too, love them. thats pretty close to my cam
Old February 9th, 2009, 01:08 PM   #32
86er's Avatar
sixty foot was a measly 1.63
I know the car is capable of 1.4x just gotta get it down, learn the car.
Its got a small reverse dish -11cc i believe, I do plan on throwing an 76-88mm on there in the future, when I dont know, built it to run nitrous at first so im gonna work that one out, then when I get bored with the juice ill hang the hair dryer on it.
I was gonna leave the stock seats in, but i decided to go kirkey to try and off set the extra weight of the 10 pt cage thats goin in it as we speak
Just a truck
Old February 9th, 2009, 04:34 PM   #33
87 Coupe
Orderin the Oil Pan today. Where should I get it from?? Jegs and Summit both have it for 135.99 but didn't know if there was a place that had it cheaper or which of the two to go with. Any suggestions??
Eats rice daily
Old February 9th, 2009, 04:35 PM   #34
86er's Avatar
thats prob the cheapest you will find that new unless you go used
Just a truck
Old February 9th, 2009, 05:32 PM   #35
87 Coupe
Can't find anyone selling the stuff used or I'd do that.
Eats rice daily
Threads Similar to: Dumb 351w Question.
dumb question jasons_98gt 96-98 7 July 14th, 2008 12:13 PM
Dumb Dumb Question on my part. mustangmanic The Clubhouse 53 July 3rd, 2008 12:57 AM
What's this? New 351w owner asking dumb questions. N. Dave 5.0 Mustangs 7 June 30th, 2008 03:25 AM
might be a dumb question.... usmcsawgunner 5.0 Mustangs 22 October 9th, 2007 03:46 AM
dumb question 4point6GT 96-98 4 June 26th, 2006 10:16 AM
