87 Coupe
![]() iTrader: 3 reviews
Dumb 351w Question.
I know this is prolly a dumb question, but here it goes. If the 302 and 351w are both the same basic block then why can't a stock 5.0 oil pan be used??
Eats rice daily
its the depth of the fox pan that is the problem
87 Coupe
from what I've read its a half inch difference. Why not use the fox pump and fox pan?? why wouldn't allk the fox pieces work then?
Eats rice daily
Billy Weston
main journals are bigger different too.....
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
87 Coupe
just doesn't make since to me yet.
Eats rice daily
87 Coupe
maybe for the stroke then?? Makes since if thats it. I'm hopin to order a swap pan soon but wanted to know why a stock pan wouldn't work.
Eats rice daily
#7 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
The 302 uses a rear-sump pan, the 351W uses a front-sump oil pan, which necessitates a new pickup.
351 Engine Swap - 5.0 Mustang & Super Fords Magazine
my 351 swap kit uses the rear sump also.......
87 Coupe
what kit did you go w/ 86er??
Eats rice daily
ford motorsports kit, it comes with dual sump pan, pick up and stud for the pick up, paid like 155 shipped from holcomb motor sports, its a stock style pan, nothing fancy
1989 Mustang LX
10.98@126.7 NA
Bolt pattern is a little different as well. Both 5.0 and 5.8 were available with both front and rear sump pans depending on the application. The easiest way is to just buy the Ford Motorsports pan and pickup.
Never fast enough.
87 Coupe
Do you see any need to get the 7 quart canton pan or is the 5 quart Ford kit just as good? I found the Ford kit at jegs for 135. Also do you run shorties or long tubes?
Eats rice daily
The Razor's Edge
with the 7 qt kit you still run 5....keeps some of the oil off the crack helps not to slow it down.....not nessasary for a DD
85 GT/86 SVO/2010 GT500
they are not the same block, 351 has a wider lifter gally,taller deck hieght,wider lower casting, same family ,not same block
87 Coupe
ahh see I've always been told they were the same just thicker webs, bigger mains, and taller deck height. Good to know. Mine will be a dd and thinkin of getting a windage tray and 7 quart when I stroke it down the road. What headers do any of you guys run w/ it??
Eats rice daily
um in the 7qt you run 7, it has more room at the bottom of the pan to keep the oil away from the crank........
we run the ford swap pan on severy mid to low 10 sec cars and have no problems, we actually put 6 in the ford pan
87 Coupe
sounds good 86er. Prolly just get that deal then. Any suggestion for headers? Are lt's worth that much more over the shorties??
Eats rice daily
The Razor's Edge
i could have sworn i seen darrell say run 5 in the 7....thats what i get for being a internet mechanic
87 Coupe
damn.....headers anyone? lol
Eats rice daily
1989 LX Vert - 1993 Notch
Fast
1 3/4 Long tubes min.
BBK makes a nice set of swap headers
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
Threads Similar to: Dumb 351w Question.
| dumb question | jasons_98gt | 96-98 | 7 | July 14th, 2008 12:13 PM |
| Dumb Dumb Question on my part. | mustangmanic | The Clubhouse | 53 | July 3rd, 2008 12:57 AM |
| What's this? New 351w owner asking dumb questions. | N. Dave | 5.0 Mustangs | 7 | June 30th, 2008 03:25 AM |
| might be a dumb question.... | usmcsawgunner | 5.0 Mustangs | 22 | October 9th, 2007 03:46 AM |
| dumb question | 4point6GT | 96-98 | 4 | June 26th, 2006 10:16 AM |
