92 mustang gt
LinkBack (1) Thread Tools
Old February 1st, 2009, 08:42 PM   1 links from elsewhere to this Post. Click to view. #1
1999 mustang gt
winterftbl can only hope to improve
92 mustang gt
Okay guys going to look at a 92, and the guy says it has no spark. It turns over but thats it. He changed the distributor and battery. Anyone know what else it could be? Thanks Guys
Old February 1st, 2009, 09:36 PM   #2
Racinjason81 is on a distinguished road
possibly the TFI module (mounted on the Distributor) or maybe an ignition coil
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old February 1st, 2009, 10:34 PM   #3
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
Check and make sure for yourself that it's not getting spark. Could be a fuel problem.
Old February 2nd, 2009, 04:26 AM   #4
'95 Mustang 5.0 (someday)
Sylencer_Sy is on a distinguished road
Send a message via Yahoo to Sylencer_Sy
And, it could be the wires. Or, specifically, the wire going from the coil to the middle post of the distributor cap. And it could also be the ignition coil. If you have a multimeter or ohmmeter available, you can test that one easily. The primary winding (between the two points where the connector goes) of the coil is supposed to read normally right around 1 ohm (or, more-or-less just about the same as a straight piece of wire), and the secondary winding (from the knob where the spark plug wire goes to the positive side of the connector plug - just try 'em both) normally reads more than five thousand but less than twenty thousand ohms (5K - 20K ohms). Now, I'm pulling those numbers arbitrarilly, but from the coils I've tested on multiple vehicles (being the only former electrician at AutoZone gives me lots of opportunities to test electrical things) that seems to be the ranges. Normally it's the secondary winding that goes, in which case once you set your multi/ohmmeter to the scale to read between 5K and 20K ohms you'll still read no continuity ("OL" on most meters, but look at what your meter says before connecting the leads, and if it's broke it won't change). I hope that helps...And again, that's only if it's truly an ignition problem. You also might wanna check the point where the ignition rotor and the distributor cap connect, though that doesn't fail that often. That, and if the distributor's changed, then normally those get changed as well...
Old February 2nd, 2009, 10:41 AM   #5
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
+1 check the tfi
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/108298-92-mustang-gt.html
Connecting Spark Plug Wires To A Distributer Cap Amc Live Wire Spark Plug Wires Ngk Wide Gap Spark Plug | Quicksilverbelts This thread Pingback February 17th, 2009 12:28 PM
Threads Similar to: 92 mustang gt
MOFO Production-Turbo 5.4 Stang-600HP Mustang GT-408w mustang-Ported Blower Cobra!! mofobucs Multimedia 24 August 20th, 2008 01:19 PM
Memphis Street Racing 4-13-08 LT1 Z28 Turbo Mustang LS2 GTO WRX STI Audi TT Mustang Mellon Videos 4 April 17th, 2008 08:54 PM
MUSTANG CLUB OF INDIANA.... MUSTANG SHOW AT THE SPEEDWAY!!! mustangmanic Midwest 0 June 27th, 2007 08:48 AM
Pirelli P6 Four Seasons fit on 17x8 mustang rims? 97 mustang DiegoAlcala V6 Mustangs 7 April 20th, 2007 09:04 PM
So Md Mustang Club 3rd Annual Mustang & Ford Show Hwyman Mid-Atlantic 0 August 8th, 2006 03:39 PM
