351W swap into a Fox body
Old January 23rd, 2006, 01:05 AM   #1
Zeek is on a distinguished road
whats up guys im prety new to fords even tho ive built my car already i want to swap a 351 fuel injceted setup into my 92 LX cuz i have the spare 351 shortblock lying around and i figure its alot cheaper to rebuild that block than to build a 347 stroker so what im wondering is what kind of modifictions am i gonna have to do for the swap and all the details of swapping that block into a fox body any help would be apreciated thanks
Dont Run Your Mouth, Run Your Car
Old January 23rd, 2006, 02:12 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You will need the correct headers for the swap, oil pan and intake. The stock harness from the 302 will work on the 351. If you are using a 5 speed, it might take some digging to find a flywheel that will work. I'm not sure which ones work but I know they are out there.
Old January 23rd, 2006, 05:55 PM   #3
87vert is on a distinguished road
Send a message via AIM to 87vert
i think the stock mounts will work but you will want to use the 'vert mounts to lower it a bit because of the taller block, otherwise you'd be looking for an aftermarket hood (yuck)
'96 Exploder XLT 5.0 AWD
"turbos coming soon"
Old January 23rd, 2006, 11:28 PM   #4
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
I dont know about that. I used factory 5.0 mounts on my Cleveland and even with a 5 inch breather, it all fits under the hood.
I have a brand new set of headers and the specs on them says they fit a 5.0 or 5.8 in a fox. You will also need an oil pan/pickup tube and proper intake combo to work with the fuel injection and match the Windsor. Other that, it should be a fairly simple swap.
As for the flywheel, any flywheel out of a car with a factory windsor/standard combo should work. I used a factory flywheel off of a 70 BOSS Mustang and it worked perfectly with the tranny, starter, clutch and pressure plate that was stock on a 5.0.
Heres a pic of my Cleveland fully dressed in the engine bay.
Old January 24th, 2006, 12:08 AM   #5
vivoronte's Avatar
vivoronte is on a distinguished road
damn nice ride bossman.....
Old January 24th, 2006, 12:29 AM   #6
Thanks.
Old November 4th, 2006, 10:39 AM   #7
sinisterfuzzy is on a distinguished road
i was wondering how you'd go about putting a 351 in a Fox Body or the Bubble Bodys. I have a fully built brand new 351W in my garage and just wanted to know how i'd put the engine in one of these cars. Thanks! btw it's carb'd.
Old November 4th, 2006, 10:45 AM   #8
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
fox bodies are not that tough...As said above...As long as you go with a 94-95 GT or Cobra becuase they still use the 302...It should not be a hard swap...
Facebook
Google+
Old November 4th, 2006, 10:56 AM   #9
how much money do you think the whole swap would be? the engine runs and everything we just pulled it out of our other mustang to restore it.
Old November 4th, 2006, 11:33 AM   #10
or what about swapping it into a bubble body that had a v6 or a later model? then is it only mounts?
Old November 4th, 2006, 11:08 PM   #11
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
These links should answer all your ?http://www.svtcobraltd.com/351Swap.html
http://www.mustangworks.com/articles...n/351swap.html
http://www.mustang50magazine.com/techarticles/18818/
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old November 4th, 2006, 11:10 PM   #12
95opal's Avatar
95 opalfrost gt
5.0 magazines
Old November 4th, 2006, 11:11 PM   #13
95opal's Avatar
95 opalfrost gt
5.0 magazines
Threads Similar to: 351W swap into a Fox body
351w swap into 00 v6 got poney V6 Mustangs 13 March 15th, 2011 04:58 PM
351W in a 94 or 95 body? built351w Modular Mustangs 18 August 26th, 2007 08:27 PM
Throttle body swap techsent 99-04 4 July 2nd, 2007 07:36 PM
'93 LX Notchback needs a 351W swap Velvet Leopard 2.3 Mustangs 1 December 29th, 2006 03:15 PM
1993 2.3L to 351W swap Velvet Leopard 5.0 Mustangs 0 December 19th, 2006 05:07 PM
