idle problem
Old February 1st, 2009, 11:05 PM   #1
94mustang94 is on a distinguished road
idle problem
Here are a list of my mods:
Modifications include:Block bored .030 over to 306 cu in.,DSS Forged Pistons,AFR 165 Aluminum Heads 58cc,Comp cams Roller Rockers,Comp cams Camshaft,Ford Racing Crankshaft,Canton 9 qt Oil pan with pickup,High flow Oil pump,30# Ford Racing Fuel Injectors,255 lph Walbro Fuel pump,Aeromotive adjustable Fuel Pressure Regulator,Ported Cobra Upper and Lower Intake Manifold,Ford Racing Shortie Headers,MAC Cat less Prochamber Pipe (stock hpipe installed for emissions),MAC Cat back Exhaust with 2 inch Chrome Tailpipes,76mm C&L MAF housing with inlet tube and K&N Filter,70mm Throttle Body,MSD Ignition with MSD coil and cap & rotor,PA Performance 185amp Alternator,Under drive Pulley Kit and new harmonic balancer,High flow Water pump,9mm Ford Racing sparkplug wires, Rebuilt T-5 Transmission,SPEC stage 2 Clutch,Cross drilled Front rotors with Hawk pads,New rear rotors and pads,Ford Racing Strut tower brace,New OEM radiator,1997 Mustang GT 17in Wheels with 245/45R17 tires like new,Pro 5.0 ShifterSteeda clutch cable
Now for my problem. I am having a problem with the way the car is idling. It likes to surge up and down really bad even to the point of cutting off. I clean the MAF and the throttle body really good. It makes the car hard to drive. Whats else could it be?
Old February 1st, 2009, 11:27 PM   #2
86er's Avatar
iac, vacuum leak, bad o2's
Just a truck
Old February 1st, 2009, 11:38 PM   #3
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
Check for malfunction codes. If there are any codes this will give you a direction to look in. I would also check your IAC motor and for vacuum leaks as stated above.
Old February 2nd, 2009, 12:34 AM   #4
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
no, go buy a new iac and new tps and problem sovled...as of right now after u start it and drive down the road the idle is pretty well, atleast not surging and stalling like it would wen u start..i had the same problem and replaced those..the car starts right up and idles perfect right away trust me
Cohagan Engineering, Inc.
Old February 2nd, 2009, 10:48 AM   #5
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
I had a similar problem on my old ghetto set up where a friend gave me a b cam and I had a set of world jr heads on my car, Every body said it was because I had a b cam on a speed density car but I replaced my iac after cleaning it like 50 times and my car idled perfect.
Old February 2nd, 2009, 11:00 AM   #6
nolife's Avatar
91GT, 88GT, 02GT
There are quite a few posts around on how to deal with idle hunting/surging. I'd look at those before you start replacing things.
Try some searches or a checklist like this one from another forum (there was one here but I can't find it now)
Help me create the "Surging Idle Checklist" - Mustang Forums at StangNet
My last idle hunting was resolved by lowering my fuel pressure a little. Really depends on your injector size and tune for that though.
Old February 2nd, 2009, 11:24 AM   #7
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
What is your TPS set at? Do you have an IAC spacer plate? There also comes a time where the IAC can not supply enough air into the motor at idle. The last car that I built a small <1/8 hole drilled into the throttle body blade cured the issue.
TT Build in progress.......
Old February 2nd, 2009, 11:28 AM   #8
TKOTLARZ's Avatar
1994 GT
thats a ghetto rig job
Old February 2nd, 2009, 12:12 PM   #9
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Its not uncommon to do this there are many cars that come like that from the factory. The actual fix is the IAC spacer..... the throttle blade couldn't be opened up more because the TPS didn't have anymore adjustment to come back down to idle. Why spend money on a spacer when drilling the throttle plate does the same thing? If you have a better way I would love to hear it.
Old February 2nd, 2009, 12:20 PM   #10
nolife's Avatar
91GT, 88GT, 02GT
Maybe
The Taurus had an idle problem a few years back and uses a similar IAB design. The Ford TSB fix was a small plate with a "pin" hole to get just enough air around the throttle plate. You can find them in a pick and pull and it will work on the Mustang as well.
Old February 2nd, 2009, 12:23 PM   #11
TKOTLARZ's Avatar
1994 GT
no jus never heard anything about that before..ive delt with alot of iac problems that were able to be fixed..if uve never heard that and hear it for the first time, it jus doesnt sound like that would be the proper way thats all
Old February 2nd, 2009, 12:49 PM   #12
nolife's Avatar
91GT, 88GT, 02GT
Followup to my own post..
If you are interested in the plate I was refering to and don't want to drill a hole in your throttle plate, search for F2PZ-9F939-A. That is the kit to allow minor adjustments of air around your IAB.
Old February 2nd, 2009, 12:55 PM   #13
JBIGBOOTSY's Avatar
1990 LX hatch
I also have done this, and it fixt idle woes.
Threads Similar to: idle problem
Idle Problem billb303 5.0 Mustangs 8 May 22nd, 2008 05:03 PM
problem with idle,, tom2000r 99-04 8 April 22nd, 2008 04:44 PM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
Idle problem StoichyGTR 99-04 1 December 22nd, 2007 02:47 PM
99 3.8 with problem Idle nweatherby V6 Mustangs 5 April 3rd, 2007 03:13 PM
