LinkBack (1) | Thread Tools |
#1
Chevy HEI in a ford
Ok so i have a 73 bronco that has a 351w out of a older stang it has the old school ignition with the ignition box. I came across a bronco on ebay that looked to have a hei distributor in a 302. After doing a little research i found you can buy these. Is there away to make your own? As much as i don't like chevy i think they had a hell of a design with that distributor. I have a hei just wondered what or if machining is required to make it work? if this is possible can it be done on my 86 gt as well it would neaten up the engine bay.
weld an hei body to a ford dist shaft..............
89 GT, 92 LX
They will work in anything, but i dont think you can machine anything to make it work. They custom make those housings.
No they don't custom make them i found a site that says they take the stock Chevy dist and machine it to fit the 302 block. I will see if i can find it.
Authorized Vendor
![]() Join Date: Sep 2008
Seems kind of like overkill; all you really have to do is take a Duraspark distributor and wire its pick-up coil to an HEI module.
89 GT, 92 LX
Some are custom made. A buddy had one and was def not a cut down chevy dizzy. You would still have to do some work on the drive shaft since ford uses a hex drive for the oil pump and chevy is a flat blade.
1988 lx t-top
I got one from procomp and it works great, but its huge so you have to modify some stuff to make it fit
I have an h.e.i. style unit on mine and it's the size of a softball, no joke, but it works great lol
weeee foooord!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/108393-chevy-hei-ford.html
| Ford 73 Fuel Injector How They Work Fuel Injector Placement Ohm Reading Fuel Injector Check | Vacavilleharleydavidson | This thread | Pingback | February 15th, 2009 11:58 AM | |
Threads Similar to: Chevy HEI in a ford
| Chevy hei dist in a 351w | 86ttops | Classic Mustangs | 13 | March 19th, 2009 02:47 PM |
| Chevy HEI in a 351w | 86ttops | All Other Vehicles | 1 | February 2nd, 2009 09:17 PM |
| ford hei | fateisajester | 5.0 Mustangs | 14 | December 31st, 2008 06:11 PM |
| Ford versus Chevy | TDog | 2005 - 2010 | 34 | August 1st, 2007 12:19 AM |
| Ford vs. Chevy | cali 5.0 | 5.0 Mustangs | 115 | October 22nd, 2006 06:08 PM |
