B&m Hammer
Old February 2nd, 2009, 07:19 PM   #1
flamestang's Avatar
flamestang is on a distinguished road
B&m Hammer
anyone using B&M's hammer (ratchet) shifter and what do you think about it?
Old February 2nd, 2009, 07:31 PM   #2
shadowgames81's Avatar
87 Coupe
shadowgames81 will become famous soon enough
interested in knowing that myself. You using it on a c4 or aod??
Eats rice daily
Old February 2nd, 2009, 07:47 PM   #3
flamestang's Avatar
Not yet I'm making plans for a c4 install.I like this shifter I just found out this was out there but never seen one.
Old February 2nd, 2009, 07:53 PM   #4
88dragstang is on a distinguished road
I have one on my AOD. I like it. My car is drag use only but I could see using it on the street no prob.
Old February 2nd, 2009, 07:59 PM   #5
87 Coupe
I'm gonna be runnin a c4 also so any info you find out will help me too.
Eats rice daily
Old February 2nd, 2009, 08:07 PM   #6
flamestang's Avatar
I found some detailed info on buying a c4.there was alot of bell housings used,cases and internal parts.this is a good one
http://http://www.mustangcentral.net/tech/c4.html
Old February 2nd, 2009, 09:46 PM   #7
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
i have heard good and bad, mostly good from people i would trust.
i have been told its hard to get adjusted correct but once its adjusted its good to go, ill be using this on my AOD in the spring.
Old February 2nd, 2009, 09:57 PM   #8
87gtmustang's Avatar
1987 mustang GT
87gtmustang is on a distinguished road
Send a message via MSN to 87gtmustang
it seems like i would forget what gear i was in... but it seems pretty bad
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump
and more to come
Old February 2nd, 2009, 10:07 PM   #9
flamestang's Avatar
it has an indicator on the base plate I was thinking the same thing when I first saw it.
Old February 2nd, 2009, 11:45 PM   #10
78mach1's Avatar
its the same as any other ratchet shifter you would find on any auto, you dont tend to forget.
Threads Similar to: B&m Hammer
B&M Hammer Shifter 90 Lxer 5.0 Mustangs 0 June 8th, 2008 05:00 PM
B&M Hammer shifter jrfan4life 99-04 1 December 2nd, 2007 01:45 PM
B&M Hammer Shifter good_fellaz_76 5.0 Mustangs 4 November 23rd, 2007 01:02 AM
B&M Hammer shifter APiratesLife4Me 99-04 2 March 21st, 2007 09:49 PM
B&M Hammer Shifter cobraetti 5.0 Mustangs 4 October 18th, 2006 08:54 PM
