Intake manifold suggestions
Im looking to get a intake manifold for my 89 5.0. I have a set of performer rpm heads as well does anyone have a intake to recomend geting. looking to spend 400 to 800 dollars. Thanx
my mods are cold air intake,70mm throttle body and mass air flow with long tube bbk headers
the edlebrock performer is good
1990 Mustang gt
edelbrock performer rpm II
2002 gt 5-speed slow 1990 gt 5-speed junk |
i got an edelbrock and i like it
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump and more to come
1994 GT
i really like my systemax
Cohagan Engineering, Inc. |
buy a used one and save some money, cant beat trickflow for the $$$$$
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." Last edited by baine21225; February 3rd, 2009 at 10:51 AM. |
holley or edelbrock. what cam are you using? if the rpm range is past like 5500 or 6k get the performer rpm II. If not, get the performer
It depends
PeteAndersonRacing.com |
I've used trickflow on three different cars with all different kinds of setups and they always performed great. Especially for the street where you would use the power. Power adder or mid to top end power i'd go with either the holley systemax 2 or eddy proformer 2. I think the holley out flows it slightly but the eddy gives alittle more torque.
here's a street heat at a great price used with a spacer FS: Trick Flow Track Heat Intake w/ 1" Spacer - Corral Forums |
isnt the track heat better than the street heat?
its made for 2 different rpm ranges
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1989 GT
KB 2.1L Flowzilla
1982 GT t-top
no proof of purchase
If your runnin edelbrock heads go with an edelbrock intake
Atomized
Street heat if your gunna keep your set up similar track heat if your gunna step it up
#16 | |
1992 Lx
11.39@119.24
/thread buy this
the street heat is a good intake I made over 476 rwhp on my turbo car with that intake unported or anything. If you need the power higher in the rpm's go with a track heat but that's a cheap price on a good intake which is why I posted it
Threads Similar to: Intake manifold suggestions
| Swapping a 98 V6 intake manifold with for a 99 V6 manifold | 98mustang | V6 Mustangs | 6 | November 20th, 2010 11:20 PM |
| Carb and Manifold suggestions | Tony_90fox | 5.0 Mustangs | 50 | September 28th, 2008 09:22 PM |
| Intake Manifold Help | 1 SNAKE 3 | V6 Mustangs | 5 | December 29th, 2007 02:56 PM |
| Intake mainfold suggestions? | StangFreak4 | 94-95 | 7 | April 21st, 2007 09:11 AM |
