Car is going to the shop today :-(
Old February 3rd, 2009, 08:28 AM   #1
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
well i still can't figure out whats up with the car and its getting worse to the point that i can't start the car hardly at all anymore...the check engine light will flash while i'm trying to start it and it just won't turn over, you can hear it wanting to turn over it just won't i did check for spark and ended shocking the shit outta myself a few times lol. but its gettin spark. the fuel pump is cutting on, not saying that mean its gettin fuel, but i'm just kinda stumped. Anyone here know what it could possibly be?? here are all the symptoms
rough idle, trouble starting,sometimes it'll start start engine light will flash and then the car will rev up on its own and die if you don't hold the rpms long enough for it to maintain a good idle. the car sometimes will feel like its cut off while riding and then cut right back on....
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old February 3rd, 2009, 08:38 AM   #2
2002BLGT is on a distinguished road
Send a message via AIM to 2002BLGT Send a message via Yahoo to 2002BLGT
What shop you taking it to ? Can you bring it down one evening and let me pull the codes for you ?
Old February 3rd, 2009, 10:02 AM   #3
Traidmarx's Avatar
1995 Mustang GT
yea i can i already dropped it off at the shop though...it took it to pit stop automotive. I was told the guy is good with mustangs he's got a Fox that says 89 SVO on the tags you probably seen it before.
Old February 3rd, 2009, 10:03 AM   #4
Traidmarx's Avatar
1995 Mustang GT
me and timmy finally got the car started this morning i had left it at lakeside kroger last night because it wouldn't start. it wouldn't start again this morning but then when timmy tapped on the distributor and the coil while i tried to start it...it fired right up.
Old February 3rd, 2009, 10:18 AM   #5
Id replace them both just for peace of mind
Old February 3rd, 2009, 10:20 AM   #6
Traidmarx's Avatar
1995 Mustang GT
yea i more than likely am going to...my only concern is trying to figure out if there is an underlying problem...the guy said he didn't know without looking at it but usually if the check engine light is flashing while you're trying to crank the car over and it won't start that its alot of times the ignition module.
Old February 3rd, 2009, 10:31 AM   #7
91 LX
13.7@101
yeah i'd replace coil and dist and i bet the problem is the ignition module
Old February 3rd, 2009, 11:36 AM   #8
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
+ not sure bout having the replace the dist. but my first thoughts were module and coil
Cohagan Engineering, Inc.
Old February 3rd, 2009, 11:48 AM   #9
modules only 20-30 bucks , replace all 3 and then you wont have to worry for a while
Old February 3rd, 2009, 11:59 AM   #10
1994, mustang gt
N/A
izze01 is on a distinguished road
Send a message via AIM to izze01
Sucks to hear ur car is messing up, Mine is acting up too and will probably have to take it to the shop soon. I am going to take my ecu and chip back to the place i had it dyno tuned and make sure the tuen and everything is on there, Mine had a problem starting too and checked the coil and module and ended up being the dizzy was bad. Best of luck hopeufully it gets fixed and doesnt cost u an arm and a leg.
Old February 3rd, 2009, 12:01 PM   #11
Traidmarx's Avatar
1995 Mustang GT
yea they're just charging me 60 to figure out whats wrong with it...i'll probably fix it myself.
Threads Similar to: Car is going to the shop today :-(
Guess what came into the shop today.. 98stangv6 The Clubhouse 8 October 2nd, 2008 07:25 PM
Car is finally in the shop! 2000stangGT 99-04 2 July 18th, 2008 03:23 PM
just got car back from shop 20gtvert03 99-04 12 February 20th, 2008 10:21 AM
took my car to the shop 232stang The Clubhouse 11 May 19th, 2007 08:27 PM
Took my car into the shop. need opinions energiesource 99-04 13 March 25th, 2007 12:38 PM
