a ticking noise
Old February 3rd, 2009, 05:16 PM   #1
87gtmustang's Avatar
1987 mustang GT
87gtmustang is on a distinguished road
Send a message via MSN to 87gtmustang
a ticking noise
theres a ticking noise coming for the driver side of the engine. it ticking when the car starts and when its running but when im costing down the road the more gas i give it the more and louder it ticks. but if im costing down it stops.
it goes away sometimes after about a 10 min ride.
i have been told to diff things. a lifter/rocker and another ideal was that its a blown gasket
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump
and more to come
Old February 4th, 2009, 01:28 AM   #2
1964 Mustang Coupe
64SoCalStang is on a distinguished road
Send a message via AIM to 64SoCalStang Send a message via MSN to 64SoCalStang Send a message via Yahoo to 64SoCalStang
If it were a blown head gasket, you would most likely have water in the oil. I would say you either have a problem with one of your rockers, or you have a small exhaust leak. It would make sense to me if it goes away after a 10 minute ride because heat causes wherever it is leaking to expand stopping the leak and the noise.
Dunn
Old February 4th, 2009, 03:27 PM   #3
Hunt_chevs's Avatar
2002 Gt
Not Slow
no headers? check your exhaust manifold bolts,... sounds like an exhaust leak
Threads Similar to: a ticking noise
a ticking noise 87gtmustang 5.0 Mustangs 20 February 7th, 2009 01:43 PM
Ticking noise cbasmas 99-04 33 October 13th, 2008 03:46 PM
ticking noise tweeters97 96-98 2 March 16th, 2008 09:31 PM
ticking noise 1 SNAKE 3 V6 Mustangs 19 February 14th, 2008 06:03 PM
ticking noise kreil45 5.0 Mustangs 2 April 23rd, 2007 02:11 PM
