87 Coupe
![]() iTrader: 3 reviews
351w Lt's
Anyone ran the hedman lt's w/ the 351w swap?? Are they worth getting over shorties? Found them for 186 new but if its not worth the extra money or will have a lot of fitment issues I don't wanna waste my time.
Eats rice daily
they make good products, wouldnt worry about fitmit problems at all, 186 isnt bad at all, that is the swap header right
85 GT/86 SVO/2010 GT500
Long tubes always better power wise
87 Coupe
yeah. its in the mustang unlimited parts catalog.....listed as 79-93 fox 5.8 long tube headers. Thinking I might get those cuz I loved the hedmans I had on my 73 but wasn't sure how the fit would be.
Eats rice daily
I put hedman's on my 92 full size bronco they fit great and never leaked
1989 LX Vert - 1993 Notch
Fast
Have fun getting them in ............................
![]() only headaches you will have is around the steering shaft. Its TIGHT. They are a royal pain to get in and out even with everything right.
![]() The last President elected in anger of previous President was ....... Jimmy Carter God Help Us |
87 Coupe
seems that no long tubes fight easily from the sound of it.
Eats rice daily
not that its not easy, just gotta manipulate some stuff, starter off on the pass side, undo the mounts on both sides so you can tilt the motor, i found it easiest to just take the steering shaft off at the rack
Fast
Nope, the stearing shaft is just a real PITA on these 351 swaps.
You have to lift the engine up some, and even then its a wrestle.
you dont have to take your starter off everytime. kooks headers fit really well. also do you have tubular front suspension?
87 Coupe
I was tryin to put them on the motor before I dropped it in and maybe even the tranny......will that make it easier or harder??
Eats rice daily
yea, put all three together, its much easier that way.
kill a bunch of birds with one stone
87 Coupe
good deal. wasn't sure if mounting the tranny later would help. Just have to find a good set of lt's then an order the pan kit and get it all put together
Eats rice daily
87 Coupe
I was reading somewhere that other vehicles w/ the 351w had the oil pan I could use. Is this true? Someone said a bronco pan could be used, is that right??
Eats rice daily
Threads Similar to: 351w Lt's
| Lt's ???? | Traidmarx | 5.0 Mustangs | 16 | January 27th, 2009 12:20 AM |
| fox LT's | 95blackbeauty | 94-95 | 4 | October 9th, 2008 05:27 PM |
| LT's and O/R H Pipe | N29468 | General Tech | 6 | June 2nd, 2008 09:26 PM |
| LT's, O/R H, and Dumps | the real shocker | 99-04 | 4 | January 24th, 2008 07:16 PM |
| LT's | thetrooper31 | V6 Mustangs | 46 | September 19th, 2007 08:17 AM |
