Cam change question
LinkBack (1) Thread Tools
Old February 4th, 2009, 02:44 PM   1 links from elsewhere to this Post. Click to view. #1
astras is on a distinguished road
Cam change question
I thought I might have had a blown head gasket (thankfully I didn't), and in the process I decided to throw an E cam in there. Can I use my old pushrods?
Old February 4th, 2009, 02:47 PM   #2
1992 Lx
11.39@119.24
i reused mine with my trickflow cam, did you install new springs? i know 2 people that have floated valves with an e cam and stock springs
Old February 4th, 2009, 02:47 PM   #3
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
yes, just do a visual inspection, looking for wear.
Old February 4th, 2009, 02:48 PM   #4
Yea, I ordered the TF spring kit... the only problem is that I mixed up the pushrods... they all look and roll perfectly though.
Old February 4th, 2009, 02:49 PM   #5
Always measure
PeteAndersonRacing.com
Old February 4th, 2009, 02:49 PM   #6
1992 Lx
11.39@119.24
the ford manual says to keep them in order but i dont think anyone does it
Old February 4th, 2009, 02:51 PM   #7
I have a set of 1.72 roller rockers that I was gonna use on my old car. Never did. Still debating whether or not to put them in.
Old February 4th, 2009, 03:25 PM   #8
M L Struck's Avatar
location does not matter because you changed cams so the two surfaces were never together before.
Old February 4th, 2009, 03:30 PM   #9
95StangMX's Avatar
95 Mustang GT
what else is done to the car?
Old February 4th, 2009, 03:42 PM   #10
The long block is stock... my intended upgrades are:
E cam and timing chain
1.72 roller rockers
headers
70mm TB
...for now.
Old February 4th, 2009, 03:44 PM   #11
95StangMX's Avatar
95 Mustang GT
I think you are going to hurt yourself more than help with the cam and throttle body. I would try and get a different set of heads first.
Old February 4th, 2009, 03:47 PM   #12
Not enough cash for heads right now... I only disassembled the motor because I thought I had a gasket leak. Already had the rockers and TB... Don't really care about performance at this point. Long as it sounds good while I work on the body and interior.
Old February 4th, 2009, 03:58 PM   #13
95StangMX's Avatar
95 Mustang GT
if you are going for sound just do the exhaust and wait to put the others in untill you get heads. or while you have it apart go to the junk yard and try to find a set of gt40's if you are on a budget
Old February 4th, 2009, 04:06 PM   #14
M L Struck's Avatar
are your heads off now?
Old February 4th, 2009, 06:19 PM   #15
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
As long as they are not damaged, position is unimportant.
Never fast enough.
Old February 4th, 2009, 06:42 PM   #16
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
you can find used gt-40's for a couple hundred bucks..dont waste ur money on the throttle body..and if u dont care about performance and jus want sound definitely dont get the cam..make sure you have full exhaust and CAI.
Cohagan Engineering, Inc.
Old February 5th, 2009, 12:41 AM   #17
1998 Cobra
13.24@105.66
headers and mid pipe will net more power than all those..
weeee foooord!
Old February 5th, 2009, 07:45 AM   #18
M L Struck's Avatar
If you have the heads off and think you can at least take out the EGR bump and gasket match the exhaust side of your stock heads
Old February 5th, 2009, 12:23 PM   #19
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Jsut to make you feel better, I have my pushrods in order at first, then that changed. I put them in all mixed up. I rolled them and checked for bends but they were fine.
If your going for sound and its apart theres no point in not putting in the cam. Thats horrible advice otherwise.
1. It might hurt but your not looking for performance.
2. putting heads off doesn't require tearing it all down, so do them later if you want. No reason to tear it down twice if you can get the cam now.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/108760-cam-change-question.html
Everything about gt40p heads - Yahoo! Glue This thread Refback February 4th, 2009 10:11 PM
Threads Similar to: Cam change question
transmission fluid change question stang300a V6 Mustangs 14 December 16th, 2008 09:52 PM
How Easy Is A Cam Change? boatn70 5.0 Mustangs 23 January 9th, 2008 10:52 PM
oil change question juan310 V6 Mustangs 22 July 25th, 2007 03:18 PM
Cam change advice hitorx 5.0 Mustangs 3 March 14th, 2007 07:05 PM
Headlight Change Question MustangMo V6 Mustangs 5 October 11th, 2006 10:42 PM
